i dont think there would be a problem with that, its a good idea.
ive got:
ae86 struts
S14 4 pots
280mm s13 rotors
Question, i see everyone from the pics have bolted the rotors to the factory hubs, ive machined done the hubs to the inside diameter of the s13 rotors, put commodore studs in the hubs and running it as a floating disc setup? has anyone else done anything like this and have they had any dramas???
My Soon to be Panda CA18DET powered N2 ae86 track car
http://www.ae86drivingclub.com.au/fo...t-s-white-AE86
That's how the standard RX7 discs are configured so set up is as Mazda intended. Some adapter plates sold from Japan to suit the FC caliper/276mm discs are offset for the over hub option. More work to fit in some ways. Machining hub down, redrill disks to 4x114.3, longer studs required and the disc itself acts as a spacer. Still may require 5mm slip-on spacer to clear caliper depending on style and offset of rim increasing track further.
with 14x6.5 (i think) with unkown offset fill out the standard gaurds awesome with no spacers, except the 14's dont clear the caliper, you shouldnt need to redrill rotors, i just went through the bendix book anf found disc that where 4x114.3 and had the same diameter as the original disc for the calipers i was running which was easy enough
what were the disc's off??
you play halo?
add me GT: samnbhnc
just a S13 (sr20det model) which is 280mm 4 stud and the S14 disc are 280mm 5 stud, so the S14/R32 (I think theres a diffrence, so i dont know which ones i have, i havnt had to get pads for them yet) but yeah so it works well, just need to sort the rears out now
This was Huw's S14/R32 set up over hub. But he's now running FC calipers and discs behind hub.
Because the Nissan disc hat is not as tall and over hub, needed a 20mm bolt-on to fit Equips (confirm?)
bump thought this was a useful thread, was anyone successful in running 14's with an rx7 caliper / ??? other model rotor setup?
Can do some 14's on Wilwood kit
yes, blake. on here is, with a 14x7 near 0 offset with a 30mm bolt on
