Results 1 to 8 of 8
Thread: ke70 - rear stud replacement
    Josh
    Default ke70 - rear stud replacement
    hey guys,
    i would like to know if anyone on the forum has replaced studs on a KE70?
    i have buggered the start of my studs, but i was just considering replacing it if it is easier then fixing it. any help is appreciated.
    thanks KKUSTOM
    Senior Member ROLL3R's Avatar
    take out you axles then hit the studs out. when replacing the studs i'd suggest maybe using longer studs then original if your planning on running any type of spacer.
    " I swear its stock officer. Just don't get me to park next to another Ke70 "
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    thats how you do it.
    pull the drum off and the socket and extention the the little holes to undo the axle out of the housing then put the drum on backwards and put 2 wheel nuts on and ue it as a slide hammer. pull the axle out and hammer the studs out.
    should only take 20 minutes each side.
    FTP.
    Dave
    ive replaced studs and not taken the axels out....
    take off the drum though.
    just smack the old ones out with a hammer. and put the new one in with a nut on it, and slowly do the nut up to pull the spline into place.
    anyone know the "NICE" part number for wheel studds that are longer?
    - Blaise Pascal
    i've heard a couple of ways of putting studs in. A: hit them in B: slot them in then put a Nut on and do it up tight to pull the stud into place. i know which one i'd do.... me lazy
    NICE, i'll find out the part number tomorrow at work as i'm planning on running longer studs on my front end anyway.
    Josh
    Wicked, thanks for the feedback fellas i think i will replace all eight studs on the rear..
    Josh
    ok just for some feedback. all i did was take the drum off. Hit the old/stuffed stud out..in to the top right hand corner of the hub...) that’s where the most room is). Then put the new stud in and torque them up to 130nm………………I hope that holds lol....thanks for all the help.
  1. FS NSW: SSR 15x9s, 17x9s, 4 stud, 5 stud, multis....
    By nebuchernezzer in forum Car Parts For Sale
    Last Post: 8th March 2011, 01:14 PM
  2. Jdm rear disc replacement
    By AIROCOBRA in forum Technical - Questions
    Last Post: 21st May 2009, 03:05 PM
  3. Help - 3 RHS rear hub stud threads ruined AE86
    By Sidey in forum Technical - Questions
    Last Post: 16th March 2008, 11:00 AM
  4. KE70/AE71 Rear wheel arch replacement flares
    By Raceflo in forum Car Parts For Sale
    Last Post: 9th April 2007, 07:34 PM
