thats how you do it.
pull the drum off and the socket and extention the the little holes to undo the axle out of the housing then put the drum on backwards and put 2 wheel nuts on and ue it as a slide hammer. pull the axle out and hammer the studs out.
should only take 20 minutes each side.
