Results 1 to 4 of 4
Thread: 20v - oem auto box -> t50 conversion
    Jun 2009
    Paul
    Default 20v - oem auto box -> t50 conversion
    Motor is a 4age 20v Silver Top.
    Complete with front drive auto gear box.
    Am wanting to attach a AE71 T-50 in place of the auto.
    Am going to need a flywheel, flywheel bolts, clutch plate and clutch pressure plate.
    What else? I guess there will be some sort of sandwich plate between the auto gearbox and the block. does this stay? or does it need to be replaced with one specific for manuals?
    Veteran Skylar's Avatar
    Ken
    You need a spigot bearing and plate as you mentioned. Manuals are indeed different to auto.
    There are tabs/mounts? on each side of the motor that bolt to block and to gearbox, they are different from manual to auto on AE82 but not sure for 20v.
    Jun 2009
    Paul
    Oh. So the actual engine block casting might be different 20v Auto to Manual.
    Uh oh.
    Anyone know for sure?
    Jonathan
    The actual engine will be the same, auto or manual.
    You need:
    metal plate, manual 4A to T50.
    8 4A-GE flywheel bolts (different to auto ones and 4A-C ones) 4A-C ones may work.
    Flywheel, any 4A-GE one.
    Clutch to suit flywheel 200mm or 212mm (can be from AE71, or AE92, AE102, or Echo? etc)
    Spigot bearing, maybe a 6001 from memory, not sure.
    block to gearbox stiffener brackets are recomended. From AE71 or AE86. 1 hole does not line up on the 20v.
    Clutch fork and throwout bearing. New bearing comes in clutch kit (different to FWD one)
    Clutch slave cylinder.
    While your at it, replace the rear main seal.
    Use a torque wrench on the flywheel bolts.
    Clutch bolts don't have to be super tight. Just use the right bolts with the spring washers.
  1. [SYD] KE70 to 4AGE conversion parts (ae71 pedal box, T50, etc)
    By the witzl in forum Car Parts For Sale
    Last Post: 3rd January 2013, 10:05 PM
  2. T50 gear box, jdm 86 radiator, 20v head 20v bits :)
    By timpy in forum Car Parts For Sale
    Last Post: 12th June 2012, 07:22 PM
  3. 20V Quads to 16V Bigport > Induction / Plenum Box
    By GeeEss in forum Technical - Questions
    Last Post: 31st August 2011, 05:47 PM
  4. 4K-c auto -> Manual conversion
    By hitoriko in forum Technical - Questions
    Last Post: 29th March 2009, 08:46 AM
  5. 20v RWD conversion PARTS. air box pics up!
    By federal in forum Technical - Questions
    Last Post: 6th December 2006, 06:49 PM
