Just wondering if anyone has some RCA's to suit RA60 struts, preferably 30mm. I know AJPS has 40mm, but i think i will run into issues running 13" rims. PM me if you know anyone or any company. CHeers
" I swear its stock officer. Just don't get me to park next to another Ke70 "
Yeah you probably will, id just go 40's and run 14's.
according to "biggo" 40mm RCS's wont fit with 13's, the info i have heard is that 25 to 30 mm is the biggest i can go without fouling on the wheel, depending on the type of ball joint. which is fair enough as i have one ball joimt that is flat on the bottem and one that has a grease nipple on the bottem... BIG difference in clearance when your talking mm's.![]()
Yeah, like i said, what car?
I'd just run 14's hey.
The setup is in a Ae71 with a ke70 flat front. If i wanted to run 14's i wouldnt of posted the question about running 13's. Cheers
Only *e7* around Melbourne running 13x8's with 215/50/13 and 235/50/13 mmm fatness.
I have thought about getting something made up. Something like this but not as crude.......
those tyres must have set you back a fortune!!
last time i heard they were around the $275 each mark!!
HAHAH I LOVE BOOST LOOSING!!
$600 for the set, practically brand new, still got all the coloured lines and nobley rubber bits on them, they were only used to roll around on in the garage.![]()
Yeah i saw the balljoint difference, i have both... one on each side, same part number though. i'll find another flat bottem one and wack it in.
