Hey guys,
Searched around a bit and didn't quite find what I was looking for.
Do any of you have experience with some of the non-name brand 20V cam manufacturers? I'd like to get something with more duration and lift, but retain VVT and not break the bank. I'd buy some used Toda's if I ever came across some that suit my needs. So far I've come across CAT cams and Kelford cams in NZ. The Kelfords aren't that cheap at about $630 USD plus shipping and duties.
I'm also looking for a cam that would work well in a 7a bottom end with 20V head if I can ever afford to mess around with that.
Cat cams has a page on 20V springs....they claim that the 20V is good for 9.5mm of lift before aftermarket tappets or springs need to be used. Springs bind at 10.5mm or so according to them. Is this good info I can go off of? Kelford recommends springs with any of their cams, but I'd rather not as my engine is pretty low mileage.
Thanks for any input!
