I'll probably use factory ECU for a bit until I can afford a stand alone. That way I can get it tuned once. So you have no complaints about those cams? Is that 600 AUS or USD?
Ideally I'd get some cams with short duration, and high lift...as long as the ramp rates are severe. We've discovered here that that's the best for emissions and streetability.
