To my knowledge my arms had not been machined down and they fit fine. I used the same arms on sigma and corona arms with no issues.
You also need to trim down the crossmember bush on to make it fit.
Ive already searched, but id like info on how to put in my Sigma arms in. Mostly about fitting the steering arms onto the ball joint......
Some say i must machine down the steering arms to fit the tapper on the ball joint, some say i dont.
Being a machinest myself im not to happy with machining the steering arm down to start with anyway as i understand how accurate this needs to be done on tappers
Im a able to use the corolla ball joints???? Do they fit?
just put the steering arm and bolt it down as tight as you can.
done.
HAHAH I LOVE BOOST LOOSING!!
