Results 1 to 4 of 4
Thread: dumping raw oil
    Senior Member PHAT86's Avatar
    Allan
    Brahma Lodge
    Default dumping raw oil
    Hi just wondering if anyone may have heard of this problem or experinced it before. I have a rebuilt 4AGE 16v with 20v quad throttle boddies, whats happening is if you start up let it run for 2-5mins give it a couple of big revs it dumps RAW oil out through the crank case breather on top of the rocker cover, i dont have a catch on as of yet. The problem is being blamed to be because the quad throttles has no crank case breather and its not breathing properly, would this be correct? what would your suggestions be.
    Any info/help would be so much appreciated.
    Kind regards. Allan
    Dave
    what do you mean by "RAW" oil? i assume you mean just the engine oil???
    and when you say "Rebuilt"? we talking new rings and valve stem seals?
    when its running normally is there any air coming out your crank case breather hole and/or oil cap?
    the only way any air is coming out of the crank case/oil cap is from excess blow by, caused by the combustion gases leaking out from either the rings or the valve stem seals.
    if the engine is indeed "Rebuilt" then id say there should be little to no air coming out of the breather hole at all. let alone oil...
    stupid question...how much oil is in it? you didnt overfill the oil?
    - Blaise Pascal
    Allan
    Brahma Lodge
    sorry yeah i mean raw engine oil and no it has not been over filled, when it was rebuilt the rings bearing pistons etc were done. From memory there was only minimal air coming out through the breather hole
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    yeha only time ive had this issue is when ive run turbo engines (which have fair crankcase breathing) and the oil doesnt return to teh sump an dfill up teh rocker covers and oveflows! The setup is gay on 4a's never heard of it on an na engine as it shouldnt happen!!!
    AE86 THE BEST
  1. Turbo Diahatsu Mira (Rare Import) 550cc of Raw Turbo Power! - (Adelaide)
    By TheLizard in forum Cars for Sale (Not Toyotas)
    Last Post: 16th October 2010, 12:36 PM
  2. raw mode fail
    By RRX-007 in forum Photography & Digital Design
    Last Post: 10th February 2010, 10:53 AM
  3. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  4. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
