Results 1 to 10 of 50
Thread: !!!!!MAD PART OUT>>>HEAPS OF STUFF!!! 180sx wrecking, ae86 turbo, w58 b/h, fmic, rims
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    Talking !!!!!MAD PART OUT>>>HEAPS OF STUFF!!! 180sx wrecking, ae86 turbo, w58 b/h, fmic, rims
    LOCATED: BRISBANE
    ITEMS:
    180SX STUFF from '94 sr20det redtop model
    2. NEW SR20DET s/s high mount turbo manifold t3/t4 comes with all bolts and gaskets(haven't even mounted it up/no motor anymore) $250...down to $200
    Manifold Pics
    4. 180sx rear hatch, with glass $300
    5. 180sx drivers side door complete $150
    6. 180sx 3" catback exhaust(cat needs to be rewelded on) 4or 5" cannon or rear $180 including up pipe!!
    picture in link at the bottom
    8. 180sx airvents got a few of them $10 or so for the lot of em
    9. 180sx Headlight Timer Assy Part Number: 28415 40F00 $10
    10. 180sx front left(passenger side) headlight $10
    11. 180sx front side indicator $5
    12. SR20 water pump pulley $15
    13. 180sx inside lights, roof and above rear view mirror. $10
    14. 180sx front crossmember with powersteering rack and arms. needs a good clean $50
    16. SR20 gearbox to block metal plate(manual not the flexplate off auto) $40
    17. 180sx rear light assembly, complete $150
    19. Front and rear GAB adjustable suspension - damper only. With SuperLow King Springs. $250 <<<<-----------
    21.Rear SR20DET rotors $20
    22. 180sx rear bar $50 champagne colour <<<----
    24. 180sx window rain/wind deflector (passenger side only) $20
    25. 180sx rubber seals $50
    Pics from 180sx
    Bunch of stuff
    Vents etc
    AE86 STUFF
    ***4AGZE smallport motor with the following parts below (2,4,8,10, and a full 3" exhaust straight through)
    ***Smallport head has been cleaned and reconditioned. Has mild porting on the inlet and exhaust. All valves and seats have been cut and lapped in.
    ***All new seals including valve stem seals and a new head gasket have been used to put it back together.
    ***It also has polished valve covers
    ***Comes with std 4agze ecu and full engine loom already to go into ae86. Loom was done by Sam who makes the Razorback ECU's.
    $1750 with CAS
    CHECK THE LINK AT THE BOTTOM FOR PICTURES OF IT BEING BUILT
    Pic of motor as it is today apart from it having the timing belt on. (pic below was before the head being rebuilt) Turbo internal gate has been welded closed to use external gate.
    Pics of motor and turbo setup and intercooler
    1. AE86 brake master cylinder. Used for 500km when the old one went then I upgraded my brake setup. $40
    2. AE86 4AGTE turbo setup. - RB20 turbo, stem pipe manifold, with turbosmart external wastegate and screamer pipe pics above
    3. 4AGE oil cooler sandwich plate and filter block(with filter) and lines(no cooler) $50
    4. 4AGZE distributor with red ignition leads(needs new cap) sold so now for the engine package it is the CAS for +$150 to engine package price
    5. 4AGZE exhaust manifold $50
    6. AE86 std steering wheel $10
    7. AE82/AE86/AE92 external thermostat $40
    8. AE86 FMIC setup using supra intercooler
    9. AE86 carbon canister $5
    10. AE86 starter motor $70
    11. 4AC water pump pulley $15
    13. 4AG(i think) iPX High Performance Oil Filter PO164 interchangable with Z386 $10
    MISC STUFF
    1. STD W58 bellhousing $100 (not 4a-w5*series)
    2. HONDA CRX D15 SOHC 16v complete motor, box and half shafts $300
    3. Flashmaster welding helmet $20
    4. Toyota XT130 tie rod ends and steering arms $20
    More pictures will be posted up if you need them.
    There is more here so just ask and I probably have it. Ive been hoarding for too long.
    All prices are negotiable.
    PM me or contact me on 0421910844
    Cameron
    Anthony
    hey can i get pics of these items please
    also do you know if the manifold will fit a 20 valve??
    AE86 4AGTE turbo setup. - RB20 turbo, stem pipe manifold, with turbosmart external wastegate and screamer pipe $400
    AE86 FMIC setup using supra intercooler $80
    JDM AS FUCK is the name of the game these days...............The Chrome Era ended in the 1990s
    Senior Member dunga70's Avatar
    Jay
    Shire
    so im guessing the w58 bellhousing is to suit 4a seriers engines?
    olympic gold keto
    Junior Member ae86 boy's Avatar
    Jul 2009
    sent you pm mate.
    Cameron
    The Gap, Brisbane
    Just a std w58 bellhousing
    Nathan
    Lilydale
    pics of turbo setup, im pretty keen. cheers
    Cameron
    The Gap, Brisbane
    PM sent
    Cameron
    The Gap, Brisbane
    Just put them up in the first post
    Cameron
    The Gap, Brisbane
    All pics are up in first post now. I dont think the manifold would fit the 20 valve. May have to redrill a hole or 2 not sure. Just what ive heard with other manifolds.
    Cameron
    The Gap, Brisbane
    1. Set of 4 Dragway 14x6 with ok tyres SOLD
  1. Fs: 99 Corolla Conquest/ 5 Speed/ 151,Oookms, Great Daily --->>> SA
    By 4A-C in forum Cars for Sale (Toyota Only)
    Last Post: 19th August 2011, 09:28 PM
  2. Replies: 10
    Last Post: 29th December 2009, 08:25 AM
  3. AE86 Stuff and fwd Stuff>>have a look inside
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 2nd September 2007, 10:48 PM
Tags for this Thread
