Results 1 to 8 of 8
Thread: xt130 corona wheel bearing torque specs
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default xt130 corona wheel bearing torque specs
    Hey just want to know what value my xt130 hubs/wheel bearings need to be torqued to?
    Can it be done without a torque wrench, IE: just by feel?
    never done wheel bearings before so any help appreciated.
    Niz
    BENT MECHANIX - Garage 20:
    Alex
    Wagga Wagga
    I normally do them by feel. One thing I have always been told is not to "over tighten" them. Just do them up till they are note and tight/firm, then give the hub a bit of a shake. If it feels sloppy, just tighten a little bit further.
    Alex's 4AGTE KE70
    Or so was thought...
    Veteran driftke70's Avatar
    Ryan
    Buderim
    the proper technique is to make sure the bearings and stub axle are well greased, then put it all together, do the nut up tight, give the wheel bit of a turn, then do a half turn back on the hub nut. make sure you use a clevis/split pin.
    this is so everything gets lined up properly, and then is at the right tension, the method above is a bit haggard to be honest.
    wheelfriends.wordpress.com
    Alex
    Wagga Wagga
    Yeah I guess it may not have been explained the greatest in words. More so not a shake but like a bit of a jiggle to get everything seated together.
    Well greasing the stub axle and bearings is a given though (I hope :O)
    And, a split pin SHOULD come with the bearing kit. But yes, it is a must.
    Alex's 4AGTE KE70
    Veteran shift_rook's Avatar
    SE Burbs
    make sure you bed em in by doin it up, undoing etc etc while spinning the wheel
    Senior Member resol's Avatar
    steve
    vic
    thats not how you 'bed in' a bearing.
    hokey is right you need some preload on the bearings, too much however will kill the grease.
    it will be obvious if you have too little preload, but no so if you have to much. so be careful. once you have put it together take the car for a quick test drive/ turning, braking etc to suss out if its too tight or too loose.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Calvin
    Kilsyth
    new bearing you do them up tight so the wheel won't spin then back it off. you want some preload on the bearings but not too much otherwise the friction will cause heat which will break down the grease.
    T18 in the build
    Niz
    South~Slide Briz
    cool, sounds easy enough.. cheers
  1. 4age big port torque specs
    By DearmanKE in forum Technical - Questions
    Last Post: 22nd December 2011, 11:57 AM
  2. help with torque specs
    By bones in forum Technical - Questions
    Last Post: 5th September 2010, 04:33 PM
  3. Torque specs 2T flywheel and clutch
    By DR1FT in forum Technical - Questions
    Last Post: 20th November 2009, 10:45 PM
  4. 3sge BEAMS Flywheel Torque specs?
    By needy1 in forum Technical - Questions
    Last Post: 23rd May 2009, 09:14 PM
  5. torque specs
    By ae86ln in forum Technical - Questions
    Last Post: 29th April 2009, 01:21 PM
