Hey guys,
Just looking at changing out the 20V stem seals. Got a price from Toyota at $266 for a full set, ouch! Going to ring up Fabre tomorrow and see if they can do it cheaper. Would anyone know of anywhere less pricey?
Also, I've read the 20V head can be quite difficult when it comes to removing the spring retainer (with head on block). From what I understand it's because the diameter of the spring and hole it sits in is quite small and most tools won't fit in. The type of spring compressor i've got consists of two legs which hook onto the spring and allows you to wind down a hollow circular bit over the retainers.
My question is, how small a diameter will the hollow circular bit need to be to fit in the spring hole? Also, will the legs be able to hook onto the spring or are they quite deep, requiring the use of a push type tool?
I know I could find out by opening up the motor, but I really want to get this done in one day, with all the right tools there.
