Results 1 to 10 of 15
Thread: What tailshaft?
    Member jdm_510's Avatar
    Ryan
    Morwell
    Default What tailshaft?
    hey guys what tailshaft do i need so i can bolt in my t18 diff?
    im just running a 4k and a 5 speed in my KE70
    thanks in advance
    Ryan
    todd
    custom dawg
    Senior Member ROLL3R's Avatar
    a better engine and gear box .... ha ha jks. Im pretty sure you use a t18 rear piece, though that may only be correct while using a 4A and T50 setup.
    " I swear its stock officer. Just don't get me to park next to another Ke70 "
    I used a ke10 1 piece tailshaft (shorter) in a ke20 with a liteace diff. You may be able to adapt something, just measure up from gearbox outlet to diff and go from there, check what is at the wreakers you could use keeping in mind uni sizes. Hope this helps.....??
    Calvin
    Kilsyth
    whole t18 tailshaft bolts in. or use ke front half
    T18 in the build
    Ryan
    Morwell
    series 1 or 2 ?
    there is a series 2 two piece at my local wrecker
    Senior Member adam's Avatar
    Adam
    A series 1 T18 tail shaft will bolt straight up to the T-series diff and K50.
    Series 2 T18 tail shaft will suit the AE71/AE86/Series 2 T18 gearboxes, 22 spline output.
    You can only use the rear half of the tail shaft you've got available to you at the wreckers.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    This man is on the money.
    Ryan
    Morwell
    can i use the front half of my ke70 on the rear half of the t18 series 2 ?
    it would save alot of stuffing around with finding a series 1 t18 tailshaft
    Lawrence
    Wollongong
    No you can't, its a common misconception that can split a KE70 tailshaft.
    Whilst you can take apart the uni-joints they don't have an unboltable section like an AE86 or TE72. So they are really just a one piece shaft with a centre bearing and extra uni. The same applies to AE71 shafts, one piece with centre bearing.
  1. Replies: 3
    Last Post: 13th September 2011, 08:56 PM
  2. tailshaft
    By wiltoi in forum General Topics (No Technical Questions)
    Last Post: 14th April 2009, 07:53 PM
  3. Tailshaft, little help?
    By matt99 in forum Technical - Questions
    Last Post: 4th October 2008, 12:35 AM
  4. What tailshaft?
    By Stomp86 in forum Technical - Questions
    Last Post: 23rd October 2007, 11:12 AM
  5. tailshaft
    By 4awagon in forum Technical - Questions
    Last Post: 22nd January 2007, 02:10 PM
