S13, 180SX, Parts, Engine, Gearbox, Nismo, Bottom ends, Heads, Manifolds, Exhaust, Turbo, Gtr rims, 5 stud, Front mount, Apexi
All going cheap need quick sale! EVERYTHING
PICS UP SOON
SR20 BOTTOM ENDS MUST GO Taking up space!
SR20DET Engine $1500
Fresh imported engine from just jap with receipt 2 months old
Gearbox with slave cylinder and line and shifter $600
Apexi turbo timer with wiring harness $100
Apexi AVCR boost controller all wiring $600
Front mount intercooler kit with piping and blow off valve $200
3" Straight through exhaust turbo back $200
Mandrel bent, high flow cat and heat wrap
s13 rear brake calipers $100
s13 skyline front brake calipers made to fit s13 $150
Nismo braided clutch line $100
Tail shaft $100
Five stud conversion kit $500
ICHIBARN from USA bolt on with genuine new wheel bearings
Nismo braided brake lines $200
R32 GTR wheels $500
With tires
REAR DIFF CV SHAFTS $50
2x sr20 red top standard turbos $100 each
2x sr20 red top heads "top end" with cams and bits $300 each
2x sr20 bottom ends $300
One seized from fuel in oil
One turns detonated piston 2
MUST GO
2x sr20 exhaust manifolds $80
2x sr20 intake manifolds $80
ECU red top standard $100
ECU red top nistune! $300
Can retune!
Tuned for 300HP fmic, disco spud and greddy easy cams
Will need retune depending on your application
PICK UP ONLY
PREFER TXT OR PM 0423428670
LOCATED IN WOLLONGONG
