Results 1 to 8 of 8
Thread: steering rack play
    Jon
    Durack
    Default steering rack play
    Car - RA60 Celica
    motor -
    use - daily
    problem - some steering/rack play
    occurs/started when - got the car
    personal situation - need to fix for roady.
    hey guys, i got some steering rack play in the RA60 and i was wondering how do i fix it without replacing the whole thing?
    when you turn it turns but doesnt feel that well grounded.
    its only a cheap daily so nothing to crazy please.
    E-Famous (Remeber your roots)
    Just get under the car and check all the steering components.
    Dave
    well there arent exactly alot.
    assuming your ball joints are not stuffed (check these first like marvis sais)
    then its your rack.
    when i first got my ke70 mine was the other way, some fool had done it up so damn tight, that the road-worthy guy picked it up straight away.
    i ended up just getting a whole new rack from the wreckers for like $40, as i think adjusting the backlash on the rack isnt as easy as winding it up till its "tight".
    im just reading through the manual for ae86 (a steering rack is a rack)
    it lists the following under "excessive play"
    -front wheel bearing worn
    -main shaft yoke or intermediate shaft yoke warn
    -lower arm ball joints worn
    -sterring system joints warn
    -steering gear out of adjustment
    in the maunal there appears to be something called "pinion adjusting screw" which is farily deep inside the rack (gota take off a few parts) it is given a specific torque (in the case of ae86 its 3.2in/lb) which your gonna need a pretty damn small torque wrench to adjust it with.
    after reading more it seems that almost all the bolts that hold the pinion gear in have a very specific torque.
    id say take it somewhere to get rebuilt/setup so you can forget about it, or just go to the wreckers and get another one! you can test them out at the wreckers too, so you dont get a dud.
    btw if you have the 98mb ae86 manual (if not find it on google) then its on page 173 or so.
    - Blaise Pascal
    Jon
    Durack
    Thanks ke70dave
    ill be looking into it when i finish moving house. will let you guys know what i find out as i have to put some suspension/ lower control arms into the car and will make sure everything is working the way it should be.
    I can get it passed easy if you like. Hit me up on pm.
    Jon
    Durack
    ok moved house and got the ra60 on the road.
    when driving along it feels like it sways side to side very slightly any ideas?
    Jon
    Durack
    can someone post pics of panrod bushes so i can check ( im still learning lol)
    yeah the wheel alignment needs to be done
    todd
    the ones in red circles
    just check them for cracks/general oldness.
  1. Replies: 1
    Last Post: 3rd July 2012, 05:33 PM
  2. Play in my rack
    By timbo in forum Technical - Questions
    Last Post: 30th June 2012, 07:11 PM
  3. Power Steering Play Q
    By bigm in forum Technical - Questions
    Last Post: 30th August 2009, 02:05 PM
  4. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
  5. Rack play
    By andru_g in forum Technical - Questions
    Last Post: 6th April 2008, 07:19 PM
