Results 1 to 10 of 15
Thread: R32 non ABS Master cylinder
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    Default R32 non ABS Master cylinder
    Car - ae86
    motor - ca18det
    use - skids
    problem - R32 non abs master cylinder
    how are the lines setup, there is 4 outlets how are the lines meant to go when installed in a 86/ke70???
    any pics of peoples installs??
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    This is R32 non-abs that I used. Don't know what you have with 4 outlets.......
    On the left R is for the rear brakes, other two marked F go to the fronts.
    I removed the original proportional valve.
    I then bent the passenger side front line to reach the newmaster cylinder.
    I then bent the rear single line to match up with new master cylinder.
    I then used the line from the OLD master cylinder to OLD old proportional valve as the NEW line for the Drivers side front, with some bending, shortening and a re-flare on one end.
    The setup didn't require any new lines, just some fiddling, careful bending and a re-flare of one end.
    Sorry I don't have any installed pics showing detail, its mostly covered by intake plenum.
    Mark
    hey.
    Did you use any proportioning valve at all? How does it feel? Reckon people thinking of doing rx7 brakes with r32 master should use one?
    Reeece
    Casula
    I dont get how your not using prop valve? does your braking work ok?
    i am halfway through this. I am going to blank off one of the front valves and keep the stock proportioning valve
    Senior Member fatke's Avatar
    Daniel
    Oakleigh South
    im not using a proportioning vavle, all i did was bent the lines with drfter 86 and made it fit on the r32 master
    CATCH MY DRIFT
    SQ ENGINEERING
    PROTEK
    NCCE ( Naths crazy corolla electrics )
    FATKE & DRFTR86....DOSEING COROLLAS SINCE 2009
    Elite rthy's Avatar
    Leo
    Tulla
    prop valve is built into it the r32 mc
    4 outlet is for 2 front and 2 rear
    3 outlet is for 2 front and 1 rear
    Oliver
    Logan Shire
    Rthy is on the money, has proportioning system built in.
    I have RX7 4 Piston fronts and T-18 Drums on the rear, proportioning feels fine and when getting certification plates the tester was impressed by the breaking performance
    Darren
    and it bolts straight onto the original studs???
    Veteran Skylar's Avatar
    Ken
    yessum.
  1. WTB... BM44 non abs Master.
    By --Redwork-- in forum Cars or Parts Wanted
    Last Post: 6th September 2010, 05:31 PM
  2. part number for R32 non abs brake master
    By Mr Awsome in forum Technical - Questions
    Last Post: 13th November 2009, 09:21 PM
  3. WTB: R32 non abs brake master
    By Mr Awsome in forum Cars or Parts Wanted
    Last Post: 1st November 2009, 01:39 PM
  4. wtb : R32 master cylinder
    By evil86 in forum Cars or Parts Wanted
    Last Post: 21st February 2009, 12:56 PM
  5. WTB: R32 Non ABS brake master cylinder
    By Sparkle86 in forum Cars or Parts Wanted
    Last Post: 20th November 2007, 11:17 AM
