Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: 4AGTE - What turbo do you use / suggest?
  1. #11
    Veteran slide86's Avatar
    Huw
    Hills
    agreed.
    a t28 with t25g exhaust housing maybe.....but not comp housing
  2. #12
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    All used on same engine setup TRACK CAR 4agte
    brand new kkr280 made 170kw on 16psi failed after 3 track days, bin job, worked well till then
    t28bb (jap s15) made 169.5kw on 18psi brilliant never failed still got it
    STREET CAR 4agte
    t28 non bb made 129kw on 12psi spooled up hard as fk but dropped oil rear seal, bought it 2nd hand.
    t28bb made 135kw on 13psi didnt seem to spool up as hard as the non bb item but is alot more reliable!!!!
    would reccommone t28 non bb cheap and good turbo
    AE86 THE BEST
  3. #13
    Reeece
    Casula
    T25g already have a .64 rear. All it means there is less volume for compressor housing to spool air into the engine, and with the t28 core + machined rear housing to suit the exhaust wheel. Its proven to give me extra 20kw at 12psi over the t28 bb thru the rev range and same top end. Reason for down grading to this setup. Its either 150kw at 7200rpm or 150kw at 5000rpm.
  4. #14
    Nsw
    Livo
    a t28 should get you the juice you want, i made 180 something kw with a bb t28 on a built gze donk.
  1. 4agte turbo manifold
    By ke70drift in forum Car Parts For Sale
    Last Post: 23rd August 2010, 03:18 PM
  2. Suggest a turbo for 300+rwkw out of a 4age
    By PRIMRK in forum Technical - Questions
    Last Post: 15th May 2010, 10:50 PM
  3. 4agte turbo options.
    By cotts13 in forum Technical - Questions
    Last Post: 29th March 2009, 12:47 AM
  4. turbo experts 4agte
    By reecegze in forum Technical - Questions
    Last Post: 13th March 2009, 05:53 PM
  5. 4agte turbo
    By spillman in forum General Topics (No Technical Questions)
    Last Post: 9th December 2007, 09:05 PM
