Great story. can't wait to see more progresss
Hi Team.
In the beginning, people thought AE86's were cool, xE7x's were the poor mans AE86, and that I was coked out of my brain for even thinking about turning a spanner on my XT130.
Nothing has changed. Love you guys.
I figured it's about time I made a build thread, as i'm finally making headway.
I could rattle off the specs, but it's not about the specs list. Unless you're a wookie.
IT'S ABOUT THE STORY, BRO.
I recieved this car in the summer of 2005 from my grandmother. It has had no other owners, although some have attempted. I win.
It looked something like this after owning it for a few months. I fitted what would be, to date, it's most notorious modification:
The racing stripe:
Oh, it also had this:
I tried to put these on it:
Which resulted in a wheel falling off thanks to dodgy autobarn wheelnuts.
A few more hits from the crack pipe resulted in this:
There were spaghetti stains on there when it was fitted.
I didn't take any more photos for the next few years.
It served me well as a daily / parts / band bus for all that time though. Did a few consumable items on it, clutch, water pump, alternator. It got broken into, also.
I then one day got motivated. After thinking of every which way i could execute every fucking engine conversion in creation, i settled on one of the easiest. And with all that motivation swelling up inside of me, got off my but, determined to do something about it. I washed the car.
And wonkily fitted some MA61 seats and AE82 Twinky wheel, the former of which are is giving me back problems. Great job.
And decided this was what I wanted it to look like:
And somehow that's covered about 4 years of ownership. Sad, really. I hadn't really done anything.
Then I bought this:
I opened it up and saw this:
I swore.
So i did some of this:
And some of this:
And to stop myself going insane doing the former, i did this:.
And after a long time, I finally bought this:
The 88253 18RG-U. It currently sits entirely dismantled.
So, how about those specs?
Where it started:
Body
XT130 Corona, 185xxx km's
Racing stripe.
Rust.
Motor
Race spec Starfire 1X
Gearbox
Borg-warner 505
Inbuilt 'when it's cold i'll crunch second' from factory
Differential
Borg-warner with rooted bearings, thanks wookie
Interior
AE82 Twinky wheel
MA61 Seats
Stereo.
Suspension
Monroe GT Gas Shocks (ewwwww) (front)
RA60 Struts
Brakes
RA60/65 Calipers (F)
RA60/65 Vented Rotors (DBA, not RDA junks) (F)
Ferodo sport pads (surprisingly good) (F)
Standard drums and shoes rear
The original plan:"And how it will sit once i've lashed a lot of money on it - "
Body:
XT130 Sedan
Rust repaired
Fresh coat of white paint
Racing stripe painted on.
Straight bumper endcaps, lol
Motor:
88253 18R-GU
Secret spec high compression custom forgies
Standard rods
Linished crank
Balanced reciprocating assembly
O/S Valves + suitable valve guides
Secret spec Frakported 88253 head
Double Valvesprings (standard, lol)
Secret spec cams (mild)
BT20V Quad throttlebodies and intake manifold
Custom adaptor
Custom extractors (tuned length)
It will run a catalytic converter and Wideband O2 sensor.
Adaptronic ECU.
Gearbox:
W50, until i blow it up.
Differential
Rebuilt RT132 T-series w/ Cusco RS LSD
Interior
Velo Seats, hopefully.
Re-trimmed JDM AE86 steerer.
Re-trim the rest of the thing in factory style.
Suspension:
AJPS Springs.
TRD Green front shocks
TRD Blue rear shocks
O/S swaybars
All bushes replaced
Brakes:
Fronts done, Rears to be refurbished when the diff is done.
Wheels will be MZ10 15x6.5"
The idea behind this car is 'Factory GT style'. I pretty much want to build this into an RT130 GT.
At present: How it actually turned out five years later.
Body:
XT130 Sedan / failbus
Rust repaired, bump strips deleted
Fresh coat of Subaru satin pearl white
Vinyl racing stripe maximum respect.
Still don't have straight bumper endcaps
All exterior brightwork repaired and polished
Re-chromed bars
Motor:
88270 18R-GEU
Racing red cam cover, for racing
'Recently rebuilt' to standard spec (confirmed)
Unifilter pod
Pacemaker extractors (I think)
2" stainless exhaust with catalytic converter
Lightweight flywheel
Gearbox:
W50, rebuilt with new seals / synchros / bearings
HD Clutch
Differential
RT132 T-series
Interior
RT132 S1 dash, instrumentation and door cards
MA61 front seats (retrimmed)
Retrimmed rear seats
Funky special "TWINCAM 8" steering wheel
No stereo
Suspension:
(front)
Friends of AJPS coilovers with 5.2kg springs
XT130 LCA's OMG
Toyshop engineering cambertops
Selbys AE86 24mm swaybar
All bushes replaced with superpro items
New tie rod ends, pitman and idler arm
Fail and aids steering box.
(rear)
AJPS springs 3.5kg/mm
KYB Excel-G shocks
relocated shock mounts on diff
AJPS adjustable banhard rod
Whiteline 18mm (maybe?) swaybar
Brakes:
Corona / Pug / Hilux fronts
(Hilux 4-piston calipers, 266mm vented Peugeot rotors, RT132 struts)
ST141 solid rear disc with single piston caliper + internal drum handbrake setup rear
MA70 1" master cylinder, wilwood adjustable bias valve
Custom handbrake linkage.
Wheels:
15x8" +/-0 Performance Superlites
225/50/R15 Toyo Proxes 4's
Superlite spare wheel.
There you go.
Hate.... now.
秀はるかに勝つ!
Is that a dinner plate as the air filter lid? hahaha
looks good in the photochop, do it!!!
lol i wanted to do the exact same stripe on my bonnet but in red for extra race!!!
LAWL
Bout time dude but 6.5's? Are you on crack? It needs 8's to look good.
At least go 7's.
an 8 +4 would be sweet with 205/50zzzz
