Page 1 of 21 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 201
Thread: ill-minded's RA65
    Ian
    Default ill-minded's RA65
    After many long years, it's finally in Brisbane. Pretty standard affair, nothing too special just yet.
    Suspension:
    Original struts converted to coilovers
    KYB Excel-G SW20 rear shocks
    Random coilover sleeve/upper hat kit from Japan
    8kg/mm Swift springs (200mm free height)
    Cusco pillow ball camber adjustable strut tops to suit xA6x
    Disc brake rear conversion from an MX73 cressida
    Falcon springs in the rear (with a couple of coils lopped off)
    Engine/Drivetrain:
    Tired 22R-E
    W58
    TRD mechanical LSD en route from Japan
    Wheels:
    14×8/8.5J -10/-5 Volk Mesh - Bridgestone Potenza RE-11 185/60R14
    14×8/9J -12/-20 SSR Mk II
    14×6.5J +6 Volk Artisan Spirit w/ aero disc covers
    Other tidbits:
    Momo Prototipo steering wheel
    Clear black shifter
    E-Famous (Remeber your roots)
    Awesome stuff
    Need to bring it down here
    Ian
    yeah, working on that bit
    also marv, you were asking how much lower i could go with my current coilover setup i think. that second to last pic shows how much adjustment for going lower there is. i think there's about 3" there, so with some 185/60r14 and dropping it as far as it goes, i could probably have the crossmember scraping
    Veteran shift_rook's Avatar
    SE Burbs
    good shit man, man those wheels ar efunny, i talked to you on msn a few nights ago with marv, good to see you on here
    Veteran Konakid's Avatar
    Henry
    Eastern
    Nice, these are drum rear end yeah?
    Plans sound good!
    Ian
    thanks guys
    yeah, drum rears standard, but i mashed up one of the swingarms slightly with a meeting with the gutter in the wet. found an MX73 at the local wrecker, so i salvaged the swingarms and brakes from that. turns out they're pretty much a bolt in swap.
    anywho, once i get some wheels (maybe across the christmas hollies if i can find some cash) i'll lower the front end and cut a coil out of the back maybe and get some pics with fitment and camber
    Jul 2009
    Josh
    Ballarat
    Looks clean man!
    Some nice wheels will set it off though!
    43ger
    Performance
    SINCE 2008
    Disk rear end is like the best mod ever, it runs an internal drum for the handbrake, with new drums and shoes locks up so awesome for drifting and stops better with the disks
    Senior Member Water Boy's Avatar
    Will look awsome with more lows and phat wheels
    Ian
    bit of an update
    got bored couple of weeks ago and decided to lower the front a bit and take out the rear springs. pics do the talking.
    then, from yesterday:
    just been under the car in the humidity and heat putting the stock shocks back in (from xE7x Excel-G), cause they keep hitting full droop when i go over bumps/speedbumps as they're not quite long enough. i'm thinking i might see if i can get some threaded spacers made up to thread onto the top of the shaft and give me an extra ~2" of overall length.
    also pulled off the rear mudflaps finally and found a nice hole in the bottom of the drivers side guard. there's rust bubbles on the passenger side as well, but they haven't rusted through yet thankfully. will look into getting some rust converter on those areas in the near future.
    ...shortly afterwards i realised i hadn't tightened the wheel nuts up on the rear and almost lost a wheel driving down the street.
    went for a walk this morning though and recovered the three nuts that went walkabout and put everything back together. all sweet!
  1. ill-minded's L70/L80 Mira
    By ill-minded in forum Other Rides
    Last Post: 26th May 2016, 07:40 PM
  2. crazy 86 lover not to mechanicly minded help plz
    By dtp05 in forum Technical - Questions
    Last Post: 4th May 2009, 09:39 PM
  3. Replies: 4
    Last Post: 27th February 2008, 07:53 PM
  4. ill draw your car
    By HiLtOn in forum Toyotas in the Media
    Last Post: 2nd May 2007, 04:36 PM
Tags for this Thread
