Page 6 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 51 to 60 of 174
Thread: Building a 7age.
  1. #51
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Thought I would ask this here. So when I put the 7AGE in the sprinter if it does raise the head up 10mm there will be a problem fitting the exhaust. How have other people got around this? Was thinking of using the Cusco engine mounts that apparently lower the motor 10mm, does anyone know where to buy these?
  2. #52
    Dec 2010
    Cal
    that will work but you need to watch the sump too. i guess depends on how tight you headers were to the body
  3. #53
    Quote Originally Posted by Adsie View Post
    should get it low enough...hard to say depending on the design of the headers i guess...
    i went to the extreme of both lower rubbers and mounts to slam the motor in the engine bay...then ran into the problem of the sump apparently fouling...which then turned into a long winded process of converting to an ae101 sump...argggggg...
    all my research into the matter was theory and conversation with others namely in the US/NZ whom had similar problems...so i havent seen with my eyes the problems...will be taking detailed pics when i get to the stage of installation however...
  4. #54
    性交を愛する
    Quote Originally Posted by adsie View Post
    was thinking of using the cusco engine mounts that apparently lower the motor 10mm, does anyone know where to buy these?
    ajps
  5. #55
    Veteran Robo86's Avatar
    Rob
    yer just mod the exhaust a little, its not TOO bad. (i used stock mounts)
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  6. #56
    Adam
    Birkdale
    Thanks. PMed AJPS about mounts pending price might just try mod the exhaust, haven't put it in yet so hopefully it won't be too bad.
  7. #57
    Davey & Riki-lee
    South Australia
    Seaford SA
    Anyone got photos of the modded key ways and pullys?
    Our introduction - Click here
  8. #58
    Apr 2010
    Granz
    Killa Downs
    Or just beat the fire wall a little thats how mine came from japan.
    I thought it was more than 10 mm?????
  9. #59
    Seamus
    Milton
    There's no need to beat the firewall at all. And yeah, it's definitely just 10mm taller.
    ^ Clicky clicky!
  10. #60
    Adam
    Birkdale
    Quote Originally Posted by AE70 View Post
    Can get photos of the modified sprocket but all it is is just another keyway slot cut to locate it at a different position on the crank
    Quote Originally Posted by SHADOW KNIGHT View Post
    Its not the firewall that will be a problem on mine, its underneath
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
