Page 1 of 43 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 428
Thread: Delazys AE86 Part Collection
    Default Delazys AE86 Part Collection
    Job: Salesperson/Storeman
    Ride: ADM 83' Toyota AE86
    Mods: 15x7" superlites, makita super lows, stereo
    THANKS go to -
    Ken - Infinite Autosports (mmm, me like run free )
    Dan and Waz - Osaka Auto Spares
    Evan - Royal Drift
    Chris - Kyouteki (chris for being a sick c**t and justin for being a tight c**t)
    Dave - AJPS
    Jay - Buddy Parts
    Aaron - Shakkato Garage
    Seamus - J-Works
    Dimitri - Compact Custom
    all the tassie boys for giving me the motivation to build something "true" and not take the easy way out like most of them
    Coming Mods:
    Engine:
    20v BT head + throttles (purchased)
    Late 7afe block + crank (purchased)
    Belfab 7afe Conrods (purchased)
    Custom Wiseco AE111 Pistons (purchased)
    288/10mm 194-D Customized Kelford Cam (purchased)
    Supertech Valve Springs (purchased)
    Supertech Titanium Retainers (purchased)
    Supertech 1mm oversized nitrated valves (purchased)
    Toda Adjustable Cam Gears (purchased)
    Toda Kevlar Timing Belt (purchased)
    RS Chita Cooling RWD Conversion/16V 4age Waterpump (purchased)
    JR VVT blanking plug + plate (purchased)
    1jz 380cc Injectors (purchased)
    1zz coil on plugs + new plugs and pins (purchased)
    RWD Alternator Mount (purchased)
    16v RWD Alternator (purchased)
    AE92 4AGE Starter Motor
    Greddy Oil Cooler + Greddy Thermostatic Sandwich Plates (purchased)
    Koyo Radiator (purchased)
    Samaco Radiator Hoses
    Cusco engine and gearbox mounts (purchased)
    SPTECH low down engine platforms (purchased)
    Adaptronic ECU tuned by GTgarage
    Powercraft Extractors
    Stainless Steel Exhaust (twin tip) (purchased)
    Lightweight Pulley Kit (purchased)
    JDM Bellhousing + T50 Gearbox (purchased) *but for how long will it last* Pineapple Racing AZN 6 Speed Conversion in future
    Footwork:
    Front Coilover - tokico hts102 & 8kg springs + helper spring (purchased)
    Rear Shock + Spring - tokico hts102 & swift springs (purchased)
    Heyman Products Modified Steering Knuckles (purchased)
    AJPS 40mm RCAs (purchased)
    Cusco Castor Rods
    Cusco Camber Tops (purchased)
    JR modified rack ends (purchased)
    AJPS Twin Adust Inners + RA40 Tie Rod Ends (Purchased)
    Modified XT130 Lower Control Arms (Purchased)
    Nagaisa Auto Traction Brackets (purchased)
    Custom Equal Length Trailing Arm Boxes (purchased)
    Custom Adjustable Equal Length 4 Link (purchased)
    Custom Panhard Rod (purchased)
    Cusco front and rear sway bars (purchased)
    T18 Series II T Series Diff (purchased)
    Cusco 1.5way LSD
    Weir Performance 4.778 R/P with billet pinion spacer
    BRAKES
    Front
    FD3S front caliper (purchased)
    QFM A1RM Brake Pads (purchased)
    Caliper Adaptor (purchased)
    RDA Mini Cooper S 294x22mm Rotors
    Braided Lines (purchased)
    R32 Skyline Master Cylinder
    Wilwood Proportional Vavle
    Rear
    ST141 Corona Caliper (purchased)
    QFM A1RM Brake Pads
    RDA Slotted ST141 Corona 280x11mm Rotors
    Corona Drum Handbrake (purchased)
    Custom Handbrake Lines
    Interior:
    Suede Cover'd Dash Skin
    Carbon Dash trimmings (purchased)
    2x Velo Milano Seats (black)
    Nardi Deep Corn Steering Wheel (Purchased)
    Works Bell Rapfix II Quick Release - Toshiki Yoshioka ToshiKing Collaboration Version (Purchased)
    Works Bell Special Edition Toshiki Yoshioka ToshiKing Gear Knob Shift Knob Gearknob Shiftknob (purchased)
    Works Bell Short Boss Kit(purchased)
    Works Bell Lockable Boss Kit Cover (purchased)
    T3 Drift Button (purchased shocks)
    2x Velo Fia 6 Point Harness (black)
    Alloy Floor Plates (purchased)
    Carbing Footrest (purchased)
    Bee-R Carbon door panels
    J-Blood carbon door sills
    Fuel System:
    Bracing:
    Cams full cage
    Cusco Tension Rod brace (Purchased)
    Nagaisa Auto Shakkaito Plates (Purchased)
    Cusco OS Strut Brace (purchased)
    T3 tri brace *adds onto cusco strut brace and braces against firewall* (purchased)
    Ultra Racing Fender Braces (purchased)
    Ultra Racing 4 Link Mid Brace (purchased)
    Ultra Racing Bomber Brace (purchased)
    Exterior:
    Black Work Meister 15x8.5-17 & 9" -29
    4 x Bridgestone Potenza Adrenilin RE001 195/50/15
    2 x Bridgestone Potenza RE01 195/50/15 *dreams*
    Customised Midnight Purple Paint *inside and out*
    Runfree type II full kit (purchased)
    Runfree Carbon Fibre Bonnet (purchased)
    Runfree FRP Front and Rear Guards (purchased)
    JDM Zenki whiteline tail-lights (purchased)
    JDM Number Plate Lights (purchased)
    JDM Kouki Foglights (foglights and bracket purchased)
    JDM Kouki Headlights (purchased)
    JDM Kouki Corner Lights (purchased)
    Genuine JDM Number Plates (purchased)
    Skid Rims:
    2x SSR MK-2 15x8.5J- 7 (purchased)
    2x SSR MK-2 15x8.5J- 19 (purchased)
    thread updated
    Veteran shift_rook's Avatar
    SE Burbs
    so many parts! so good being able to keep to a plan. this car is going to be epic when it's finished
    Joe
    Bellbowrie
    wow..........sounds awsome, and i want your rims! mk-2s as skid rims! jelous
    stay classy
    Veteran slydar's Avatar
    Dimitri
    offset is worth reconsidering. car wont steer too nice with -17 on the front. try to keep it close to 0.
    8.5 -17 is mainly due to wanting to run r-disk in hope of clearing fc3s calipers without needing spacers...other option being running o-disk 9 -3...
    meisters would only be a pose/look good rim anyways *yes im a big girl*, mk2's would be used anytime the car is going to be actually driven
    thats awhile away yet with the current exchange rate making it near impossible for me to justify buying brand new meisters
    Ken
    Spearwood
    Delazy doesn't care about the massive offset front, cos the car is a show pony, trailer queen, garage king and will never move.
    hahaha...wats that ken u arsehat?? u want to meet me in adelaide once its complete and settle this in the adelaide hills?? hahah
    stop whinging, ive kept u in business from the other side of the country
    most of my parts in are boxes locked away so i cbf'd taking pics...nothing really worth showing anyways...wait til the car is done and ill take millions of pics haha
    Really Intrested to see how the motor goes once done. Should be a nice street go'er.
    well these arrived today woot!!! 15x8.5-19...
    now ive got a full set
    15x8.5-7 and 15x8.5-19
    and yes seamus did finally give in haha
    also got a set of 1zz coilpacks and ae111 wiring loom on the way from ant kellam and jonny rochester will be working his magic on a few littles bits and pieces for me soon
  1. delazys epic collection of parts *clearance*
    By Delazy in forum Car Parts For Sale
    Last Post: 12th February 2012, 08:04 PM
  2. Dvd collection for sale - melbourne
    By hitoriko in forum Other Items for Sale
    Last Post: 17th March 2011, 07:57 PM
  3. My collection so far.....
    By us_ae86 in forum General Topics (No Technical Questions)
    Last Post: 14th August 2007, 12:49 PM
  4. Best Motoring Collection
    By Tom86 in forum Toyotas in the Media
    Last Post: 23rd February 2006, 12:05 AM
