Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 10 of 96
Thread: My 4agte tuff daily build yo!
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Cool My 4agte tuff daily build yo!
    So my name is Adam and ive been lurking on these fourms for a while now, id thought i will post up my build.
    Its a 1984 KE70, with about 230,000kms. Maybe some of you saw it but i had it up for sale here a few months back after slowly loosing interest in the car.. well happy to say im glad i didnt. It had the standard 4k, 4speed in it, and i was trying to break it for an excuse to put a 4age in it, but i had no luck luck and failed!! It just wouldnt die. The car has been my fun daily for about a year and a half so i though id clean it up abit, throw some carpet back in her and give this thing a bit of love!! Simple!
    So one day i was in it and started pulling stuff out to clean up the wiring! One thing lead to another and within a few hours i had completly stripped out the interior. Scratching my head not knowing what i was actually trying to do. The next weekend somehow the 4k was out 4 speed was in the bin and grease under my finger nails. What i was left with was pretty much a bare shell. The missus came up to me and said very politely..What the fuck are you doing?? and i said i dont really know! just trying to clean up some wiring. HAha
    So..dont know how, but somehow i found a excuse to do my first conversion.
    check out some PICS....
    Seing as this car will be my daily and sometimes track this is what my wish list looks like
    4agze converted to turbo
    t50
    t series
    coilovers
    put some carpet back in
    re bush everything
    bracing
    brake upgrde
    and of course all the little bits that go in between.
    Pretty standard upgrades but lets see how i go. probably not gonna be the fastest of builds, but let's see how it goes
    feel free to comment
ID:	24556   Click image for larger version.
ID:	24555   Click image for larger version.
ID:	24554   Click image for larger version.
ID:	24553   Click image for larger version.
ID:	24551   Click image for larger version.
ID:	24550   Click image for larger version.
ID:	24549   Click image for larger version.
ID:	24548   Click image for larger version.
ID:	24546   Click image for larger version.
ID:	24545   Click image for larger version.
ID:	24544   Click image for larger version.
ID:	24543   Click image for larger version.
ID:	24541   Click image for larger version.
ID:	24540   Click image for larger version.
ID:	24539   Click image for larger version.
ID:	24538   Click image for larger version.
    May 2010
    Adam
    St George
    BTW the intercooler in the first pic is way to big 600x300x70 for my liking..
    i will be going a 520x220x65 it will be a much better fit i think.
    May 2010
    Adam
    St George
    So anyway i though id share my experience with installling my AE71 pedal box. Ive seen abit of info using templates and stuff and to honest there is really no need.
    It was a piece of piss, and took all of about an hour. Keeping in mind i had all my dash out. I probably wouldnt even bother working around everything id just rip it all out.
    Ignoring the holes i have already drilled, get the pedal box mounded in and nip up all the bolts making sure the brake booster is in. Get up under the steering wheel with a small screw driver and punch the 2 holes that need to be drilled. Dont hit it too hard just enough to get a mark from the engine bay side. This is where the red arrows are pointing.
    Next thing to do is simple..From the engine bay side you should not have 2 small pretrusions from where u just hit.. get a centre punch and hit it the other way. Now u will have both holes centre punched perfectly. Before you drill them scribe a line straight down the centers, than half way between. Done!
    Where these 2 lines cross this is the middle of the big hole u have to drill. Save yourself the hassle and just go out and get a hole saw.
    Once drilled throw some paint on it and Slap on a Clutch Master!!
    I've installed 2 of these now and both times I didn't get the hole perfectly aligned..
    You cant tell but still it was annoying to get it wrong and have to enlargen the hole with a die grinder.
    May 2010
    Adam
    St George
    Yeah the way i did it i was really happy the holes lined up perfectly, and a hole saw made the job headache less!
    So today i went and picked up a few bits and pices. Got myselft a T25, T-series and some other stuff to go with it. just gotta source out a turbo manifold now. I probably want to go a low mount system.
    So i was just thinking about the tail shaft and i was wondering if a ke70 front half will go into the t50 box?? will it work with the rear half out of a ra40??
    Tommorrow im and gonna swap the huge intercooler i bought, for one a little bit smaller lol hopefull get some brakets made during the week and have that all mounted.
ID:	24568Click image for larger version.
    Stay tuned...
    Member Philbo's Avatar
    Phil
    NT
    Darwin
    Looks good man, i like the black bay and intercooler mounting. I mounted my intercooler the same and i'd agree a shorter one will be much easier to route the piping.
    KE70 tailshaft won't fit an AE86/71 T50, however it will fit a T18 or TA22 T50. 86 front shaft with T18 rear shaft is the standard recipe for 86/71 T50s to T series diffs.
    Quote Originally Posted by Tim.duncan View Post
    Will you post #4 piston and the centre bearing from the turbo to broom?
    May 2010
    Adam
    St George
    So today i went and changed my cooler for something more practical..i got a 520x220x60. Fits in real nice and pipe work will look neater. Might just throw a can of black paint at it to give it the stealth loook
    gonna sort out a new radiator probably just go a ebay special..make some mounts during the week and get them both mounted it.
    next on the to-do list is put a fitting in the sump for the oil return from the turbo. after that i should be able to bolt the box up to the motor and settle them both into thier new home.
    Cant wait to do some skids!!
    Random pic..."Mad Camber Bro"
    May 2010
    Adam
    St George
    Bit of an update on my progress...
    Been abit bit busy latley havent had much time to play with, but today i got some stuff done. First of all i took the sump of the motor so i can take it into work on monday and weld a oil return for the turbo. hopefully have it back on mid week. I bought a excedy heavy duty clutch so now i can finally mate the t50 and motor together. Also bought a new gearbox rubber mount. Alot of fucking around trying to put them both in seeing i have only got my car on stands, but i got there in the end. Im using a ae86 gearbox crosmember and to me it doesnt look good, as only 1 bolt either side lines up. Has anyone got and other ideas of what cross members to use or will the ae86 on be ok?? any advice?
    Progress shots..
ID:	24778Click image for larger version.
    Test fitted the intake manifold, and all looks sweet now the cooler and intake manifold is all sorted i should be able to start plumbing that side of things up. I should have a turbo manifold all sorted by next week so than i can mount up my little hair dryer and work out the piping on that side.
ID:	24777Click image for larger version.
    I was looking at the clutch slave and masters and is it reallly nessasary to run the hard lines?? can i just use a braided line straight to both cylinders?? Will this cause any issues?
    Thought i would add what mods i plan for the car..
    4agze AFM CAS
    T25 turbo (for now)
    Stainless steel low mount manifold ( untill i make a steam pipe )
    front mount cooler
    standard 4agze cpu
    ae71 pedal box
    ae86 engine cross member
    ae86 steering rack
    s13 brake master cylinder
    JDM T50
    T series with some sort of 1.5 way
    15'' Superlights
    Xt130 LCA
    Ae86 JDM brakes
    BC coilovers
    new bushes everywhere
    strut brace
    adjustabe panhard
    ae86 efi petrol tank
    thaats about all from the top of my head but i will update as i go on.
    Random Pic
    Well i think thats about it for now. Just gotta get and few more things sorted and i guess i can start on the wiring wich i have been putting off since day 1!
    more to come..
    Jan 2012
    liam
    nsw
    kyle bay
    i like this car because it is the colour red
    May 2010
    Adam
    St George
    ^^^ This guy!! it should go faster to.. being red and all!
  1. 4AGTE Keto Build.
    By milto in forum KE70 / AE71 Owners Forums
    Last Post: 6th August 2012, 12:26 PM
  2. The daily build
    Last Post: 10th January 2010, 06:04 PM
  3. My New 4AGTE Daily
    By 44GTE in forum AE86 Owners Forums
    Last Post: 9th January 2009, 02:16 PM
  4. 4AGTE Build Specs
    By orangechargd86 in forum Technical - Articles
    Last Post: 27th March 2008, 11:10 PM
  5. KE70 Daily build up
    By -Leigh- in forum KE70 / AE71 Owners Forums
    Last Post: 10th September 2006, 10:57 PM
