Results 1 to 10 of 16
Thread: My KE70 build
    Member Anthony13's Avatar
    Jun 2012
    Anthony
    Yarra glen
    Default My KE70 build
    Hey y'all Im new here so I thought id fill you all in on my little project! I've recently brought a ke70 and am in the process of gathering all the required parts for a 4age conversion, I've got almost everything I need just waiting on a few little bits.
    Now this car will be my new daily and replace my current one so there's no rush to do so that's why I'm
    Taking my time making sure
    I get it right first off! I've also got a Nissan s14a that's my baby and here's my corolla,
    The car was in pretty good condition when I got it there's only a tiny bit of rust in the boot where the rubber seal is but thats easily fixed! Its has also been lowered to some extent!
    Um now I've just finished putting my motor together here's a pic of it the day I picked it up and after I gave it a good GOOD! Clean! LoL
    And here's what it looks like now!
    I've just basically given it a spruce up lol! I plan to put a set of ITBs on it from a silver top 20v which I already have! And the other essentials like cams and a good exhaust system! Ive already got a greddy eManage for it as well!
    Now I've got a few questions in regards to my intake manifold! After I brought the motor I was going to get my fwd manifold cut and shut! But I found one eBay for a good price so I brought it and just swapped everything over from my old one to the new one and when I did so I realised that the new RWD one was missing a hole they have welded over it and there's a sensor that's ment to go there but I don't no if I need it or what can some one tell me what this sensor is for
    This is my fwd manifold and I just took this pic to show you all what I was craping on about!
    That yellow plug / welded hole is a temperature input sensor.. A particular model bigport had them in the airbox in FWD format where as most had them in the inlet manifold.. So find yourself an air intake temp sensor + a plug and hook it up. If you don't have an airbox hang it somewhere near the throttle body / pod / whatever you are going to run.
    Build is starting to come together nicely, take your time do it right and don't be afraid to ask questions if you need help...
    Jun 2012
    Anthony
    Yarra glen
    xxx
    Personally i've never used a cut n shut one, but obviously something isn't quite right with it for it to be fowling.
    Have a look at the pics of this jdm one on ebay... You might be able to work out what is wrong.
    SC86 or Justjdm can sort you a jdm one if you decide the cut n shut is no good.
    Jun 2012
    Anthony
    Yarra glen
    Hey it's been a while since I've posted anything so i thought I'd put up some progress pics
    Motor and everything out
    Dash out!
    Engine bay painted ready for clear!
    Clear coat done pedal box and the rest done crossmember fitted!
    Motor ready to go in
    Motor in note I was up till 4 the night befor I put the motor in doing shit ie sticker bombing! LoL
    Jun 2012
    Anthony
    Yarra glen
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Looks the goods mate nice and clean
    Jun 2012
    Anthony
    Yarra glen
    Thanks man it's getting there slowly
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    i like that. Slowly but properly
    quit hatin get bakin!
    Jun 2012
    Anthony
    Yarra glen
    Hey all I thought if give an update on my KE70 build,
    First up, my engine loom it was fwd one so I ha to modify it to fit nicely,
    And now everything's back together and working!
    I just finished putting all the interior back In and am in the process of wiring up my gauges,
    The OMORI gauges I have are a little troubling to install with all there wires and that but I think I've got it all sussed out,
    Hopefully it's all done tomorrow and I can then cut and polish it, I did a sample of the roof ages ago and came up okay Click image for larger version.
  1. Ke70 Build
    By Low Style in forum KE70 / AE71 Owners Forums
    Last Post: 23rd July 2012, 10:38 PM
  2. JayDee's KE70 build
    By JayDee in forum KE70 / AE71 Owners Forums
    Last Post: 6th June 2011, 11:26 PM
  3. KE70 build up.
    By miniman1 in forum KE70 / AE71 Owners Forums
    Last Post: 20th May 2010, 05:03 PM
  4. ke70 build from ae86
    By damo_00 in forum Technical - Questions
    Last Post: 14th May 2008, 03:10 PM
  5. KE70 Build
    By nelpd96 in forum KE70 / AE71 Owners Forums
    Last Post: 28th February 2007, 03:56 PM
