Results 1 to 10 of 20
Thread: 20v bt aftermarket ecus
    gawler area.
    Default 20v bt aftermarket ecus
    just seeing what people are using in the aftermarket range of ecu's for there black top 20v.
    hachi roku
    Either sprint 500 Haltech or Adaptronic from Kaizen Garage are the ones most people use....
    Sutherland
    I ran a Haltech on my BT20v, made 108rwkw and very streetable.
    Moderator Frak's Avatar
    Jamie
    Autronic SM2
    Hachiroku since 1994
    ^^ knew it would be either yourself, tim duncan or pat contributing the autronic suggestion lol
    Jamie
    Because it's a great ecu, I've been running the same SM2 since about 1990, all it's had is processor upgrades and new laptop software to keep it up to date, I wouldn't use anything else.
    gawler area.
    frak do many tuners in adelaide play around with the Autronic SM2 ?
    hachi roku
    Ridgehaven
    Jaustech
    still not set on which ecu will be used in my car...still sometime before i feel the need to decide...will hit you up for opinion and/or give you the absolute opportunity to convince me...either way it needs to have a racepak/motec/or other dash ability...
    tim has told me numerous times how highly you speak of autronic however...while not a frontline option, i am open to suggestion...ps1000/motec of some description currently lead the charge pending wallet at the time...
    Best advice i was given was pick the one your tuner is most comfortable with... The price gap between haltech and motec isn't as great as it used to be now they have their new range.
  1. are bt 20v and silver top 20v cam covers the same??
    By slider4life in forum Technical - Questions
    Last Post: 1st April 2010, 06:08 PM
  2. 20V BT VVT with aftermarket cams
    By 86JAP in forum Technical - Questions
    Last Post: 13th March 2010, 05:14 AM
  3. 20v ecus
    By Rich_86 in forum Technical - Questions
    Last Post: 18th January 2008, 06:55 PM
  4. Aftermarket ECUs ?
    By Jonny Rochester in forum Technical - Questions
    Last Post: 29th December 2007, 06:39 PM
