Results 1 to 8 of 8
Thread: Head lights won't turn off!!??
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Head lights won't turn off!!??
    Ok this has me baffled, I've been fiddling around for hours and can't seem to find a fix
    After my 4age into ke70 conversion my headlights won't turn off regardless of where the switch is. As soon as I connect the battery the lights come on. I'm pretty sure I never touched any of the headlight wiring. Has anyone had this problem? And sudgwstiobs of what I can try..
    thanks
    West
    There is a relay that controls them, maybe its stuck on.
    May 2010
    Adam
    St George
    I can hear a really clicking when I turn the switch, would that mean its working ? Where is the relay anyway
    Junior Member Dexter's Avatar
    Mar 2012
    Dexter
    Nsw
    Mine done it last week. Slowly the headlights would turn on. And a buzzing from the relay. I change the relay and it fixes the problem. Might help you to change it and go from there.
    West
    The relay could theoretically click and still be broken and stuck closed.
    Logically Im thinking relay as it will have a full time 12v source or you wouldn't be able to use the lights when the car is off.
    The relay simply waits for a control circuit to close and then gives its target access to 12v constant from the battery. It could potentially fail and stay on all the time, its just as likely as if it were dead all the time. Logically its hard to look past that problem, as its the relay that controls it. Next step would be the other control equipment, maybe the headlamp switch on the stalk is stuck on, but I feel its less likely, they tend to wear and to tend not to turn on when dirty or loose.
    So go get the same type of relay from the wreckers and swap it out. The headlight relay will be located in the fuse box next to the battery on an ae71 or ke70. its a different type of relay than what you would buy as an aftermarket relay, a circular silver metal one. Most any corolla up to the 90s would use the same headlight relay. If you cant find one I have a few, I'm sure I could send one if you want it. I believe the relay is inverted in its operation to a normal relay.
    May 2010
    Adam
    St George
    I changed them around with one I'm sure works and also swapped the around with the ones in the drivers kick panel, still no luck!
    On the ae71 the head light relay is in the engine bay and is the one in the middle next to the starter which is just a 4 pin plug with 2 wires connected.
    Take it out and see if the headlights turn off
    May 2010
    Adam
    St George
    All sorted after stuffing around with the headlight switch the head lights are working fine WTF! maybe it's on the way out. Same thing was happening with the brake lights to find it was a faulty brake switch.. All gogood
    Cheers for the help
  1. Dash lights turn off.
    By Ade_Mc in forum Technical - Questions
    Last Post: 3rd November 2010, 09:41 PM
  2. trueno head lights
    By sic86 in forum Car Parts For Sale
    Last Post: 23rd May 2010, 12:34 AM
  3. 86 head lights.
    By lil_cons in forum Cars or Parts Wanted
    Last Post: 28th October 2009, 06:32 PM
  4. Engine won't turn over, seems to be seized.
    By PULSE in forum Technical - Questions
    Last Post: 2nd September 2008, 04:43 PM
  5. Replies: 3
    Last Post: 11th July 2008, 06:57 PM
