Results 1 to 4 of 4
Thread: i have no idea what im doing
    Oct 2011
    Dion
    wagga wagga
    Default i have no idea what im doing
    stay tuned
    ryan
    Take 2! i reckon start simple with this one, get some track time under your belt with a basic set up then work from there
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    Needs more low
    quit hatin get bakin!
    Oct 2011
    Dion
    wagga wagga
    so what was supposed to be a cheap daily build is turning out the same way they usually do, purchased front 86 coil overs with cusco tops, Koni front and rear shocks, rear springs, built 4ac with 264 cam, shaved head, 100thou oversize pistons all new bearings etc, Mikuni quad carbs off an fj1200 yami. cheap recline-able race seats, t50 box and shaft etc
    few more pics cause everyone loves pics, scored it for $100, ae71, auto, minimal rust..
    couldn't be bothered fixing the spare wheel well so welded in a flat piece and re covered it with carpet, under body deadened the underside
    all hanging panels removed
    coat of Toyota supreme white on all the door jams and inner jams/panels
    couldn't help my self and pumped the flares out a bit.. had rust in the rear ones anyways
    now im up to the stage of stripping the paint off the outer panels, have the roof in primer
    petrol that had been in the tank since 2008 lol
    rear window is also out, wasn't gunna take it out but lucky i did as some idiot didn't run sealer around the top of the rubber and dirt/water has been sitting around for a long time and its rusted the whole lip out about 2 inches long
  1. no idea!!
    By boy666 in forum Technical - Questions
    Last Post: 4th May 2012, 11:57 PM
  2. Is my idea feasible??
    By hugh in forum Technical - Questions
    Last Post: 4th June 2008, 04:40 PM
  3. Catch Can Idea
    By medwin46 in forum Technical - Questions
    Last Post: 2nd August 2007, 06:59 PM
  4. A new conversion idea.
    By slidin 86 in forum General Topics (No Technical Questions)
    Last Post: 5th April 2006, 09:34 PM
