Page 31 of 62 FirstFirst ... 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 ... LastLast
Results 301 to 310 of 613
Thread: Andy's 'IPRA' Coupe
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Hm, if you got that much of a jump maybe i should switch to E85 too.
    Who did the tuning if you dont mind?
    Veteran AJPS's Avatar
    Lonsdale
    i thought most people usually got 30% with e85 with turbos and about 25% with NA?
    Senior Member lawrencelalot's Avatar
    Feb 2010
    Jack
    Glynde
    That much? That's massive.
    Josh
    goood work andy....did people have there fingers in their ears??..lol
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    I sure did, and so did everyone else!
    Andy
    Andy
    Adelaide Hills
    Mike dale did the the tune, I'm not sure what he can tune other than haltech though. I'd recomend using e85, obviously makes more power, but it made more power higher in the rev range now as well. He lifted the rev limiter up 500 at it was still making power on the limiter
    Andy
    Veteran Touge Boy's Avatar
    Modbury
    Some people just need to harden up>
    Dont you touch that exhaust andy!
    Great work on the power gains, and best of luck @ superlap.
    yeh, werd, dnt touch the exhaust...loudness' ftw...
    without reading back thru the whole thread looking for specs...quite interested in the engine (parts and compression) and fuel system specs...
    Andy
    Adelaide Hills
    264 cams, headwork, compression is about 10something to 1 obviously the quads and stuff, it's got 7m injectors in it now too.
    Andy
    impressive figure for quite a basic engine...E85 seems to have worked its magic...most other results on N/A applications ive seen havent been all that impressive unless the CR was thru the roof 13:1+
    gives me faith ill crack the 130rwkw mark with my motor (built ae111 head, 288 degree cams, built 7a bottom, 11.5:1, 2jz injectors)
  1. Andy's Levin Coupe
    By 4AGE - 86 in forum AE86 Owners Forums
    Last Post: 2nd August 2008, 03:33 PM
  2. Andy's other levin coupe
    Last Post: 4th April 2008, 10:38 AM
