Page 22 of 26 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 211 to 220 of 253
Thread: custom steering Knuckles and getting max lock
  1. #211
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    There's a huge difference between bending and cutting+welding...
  2. #212
    Veteran johl's Avatar
    Johl
    taken from jase's build thread who posted on the previous page
    rack is forward 30mm
    his own modified knuckle on top vs stock on bottom
  3. #213
    Mar 2010
    Drew
    Lilydale
    chopping and rewelding is a damn sight safer and stronger than bending, clearly you have no idea how metal works, if somethings bent, its weakened, it will bend again
  4. #214
    Mar 2010
    Drew
    Lilydale
    oh, and bending several times on a think solid peice of steel ultimately means SNAPPING, if you want your shit to snap, by all means bend it, or run the knuckles that have been breaking at track days in victoria
  5. #215
    Todd
    Auckland
    Auckland
    New Zealand
    but there is only so far you can move your rack before other things get in the way like the bush and arm itself, so there is no way you can go past the straight of the arm and have any mechanical advantage left... so no reason to notch the arm
    (even if you change the bush to a rose-joint and also offset mounting point on the crossmember you will still only get the tie-rod in line with the arm, so you still really need a 7-10mm stopper, even better if you use a stopper that is raised and stops the steering arm not the ball-joint)
    (i've run a moved rack for a fair few years now) since back when i was drifting with a k series, you should move the rack on any setup you are getting the bail-joint near the lower control arm
    the pursuit of angle
    Custom cut+shut knuckles made to order, in new zealand
  6. #216
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    I don't understand how you can say there is no advantage to notching the LCA..?
    My LCA have a pretty massive amount missing, and my set up only just goes into bind when the rack end buttoms out in the LCA... And due to not having long enough rack ends I have to have my LCA shorter than I'd like which means my wheels rub the rail befor that any way..
    But I do agree with most other things.
    An very basic setup of Lock spacer and angle corrected arms results in heaps of lock..
    And also as you said. There is little point to making them too short..
  7. #217
    Todd
    Auckland
    Auckland
    New Zealand
    maybe mspaint can help explain better?
    you barely have any mech advantage when hitting the lower control arm at full lock (if any), most people drive around this using weight transfer and caster to pull them out, but when you get it slightly wrong you can't pull it out of the slide when you want
  8. #218
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    if you have moved the rack as forward as possible, and you have notched the lca's and you run into binding issues, you are clearly doing something wrong
    the wheel would be hitting the rack end before it binds........ or something else ridiculous
  9. #219
    Jason
    Nundah
    But just look at the awesome angle differnce
    [/QUOTE]
    Tom I'm not sure what your implying.??
    Moving rack forward = less chance of bind.
    Notching LCA = more chance of bind..
    And As I've already said. My setup phiscally can't go into bind because the wheel runs out of room to turn.. If I had no wheel then yes it can and does bind. Mind you the angle this acheives is fairly stupid...
    Annnndddd I'm pretty sure I did mention that I can over come this with a slightly differnt knuckle design and longer LCA when I can find an appropriate rack end to give me the length I need.
  10. #220
    Mar 2010
    Tom
    Ashmore
    not sure where you got that first part from
    second bit about not being able to go into bind is what i was trying to say.
  1. T3 Ae86 Extra lock Steering Knuckles
    By sundee in forum Spirited Drive
    Last Post: 20th March 2014, 07:02 PM
  2. Lock spacers and custom steering arms
    By trikzlane in forum Technical - Questions
    Last Post: 2nd September 2013, 07:25 PM
  3. T3 Ae86 Extra Lock Steering Knuckles
    By PRIMRK in forum Car Parts For Sale
    Last Post: 15th October 2011, 06:33 PM
  4. KE70/AE86 Custom lock Steering arms
    By trikzlane in forum Car Parts For Sale
    Last Post: 15th May 2011, 07:11 PM
  5. S13 custom shortened steering knuckles
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 10th December 2009, 07:55 PM
