Page 22 of 31 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 LastLast
Results 211 to 220 of 301
Thread: F series Diff info + Discussion
  1. #211
    Member gaspal's Avatar
    Richard
    Osborne Park
    Ok disregard previous post but for future reference, KIT2888 crosses over to TJ237KIT from CBC so its the same kit but different numbers for covs, veals etc. $68 each
  2. #212
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Deleted.
  3. #213
    Seth
    yeah, bearing listings can be a real pain the best of time's
    MATT: sssshhhh!! lol.
  4. #214
    Member phil's Avatar
    Phil
    Sutherland shire
    Anyone know if it's possible to get new crown n pinion gears? And not overly expensive... After 3.9s or 4.1s
    I currently have a yr22 tarago 4.3 centre so hoping to just swap over the gears and get it all rebuilt
  5. #215
    West
    I have 4.1 f gears from a low mile altezza if youre interested. Send me a pm if youre keen, I used the original 3.9 gearset in my f diff build with the altezza lsd.
  6. #216
    Phil
    Sutherland shire
    Yeah I might grab them off you, I'm trying to source another spare diff but if that falls thru ill pm you
  7. #217
    Ian
    Just in case anyone is ever trying to identify an F series TRD centre, here's some handy pictures. The part number is: 41301-RA010
    There's also some confusion about the TRD centres being swappable from 1.5-way to 2-way, but the F series diffs at least are limited to 2-way only. There's a note on the TRD parts page about all of the FR diffs being 2-way only as well.
  8. #218
    West
    Does anyone know the torque bias ratio of the type 2 torsen lsd the rs200 has? Been curious how mines going to behave. I read morst FR application torsen type 2 diffs are between 2-3 : 1. I just cannot find any specifiec info.
  9. #219
    Veteran Konakid's Avatar
    Henry
    Eastern
    Alright guys ive bought an SXE10 Altezza Cusco RS 2 way for my YR22 Tarago live axle diff. Got 3.73 ratio centre from an F Series IRS corona that im using the CW + P of. Should this all go together ok? I'm going to tell the diff shop to give it a full overhaul so new bearings and seals and crush tube etc.
  10. #220
    West
    Should work. Some people talk about shimming the gears to make it all line up, but the diff shop I used was pretty tricky and were able to use slightly odd width bearings to correct it slightly. I used MX13 3.89 gears from the original diff, as they were mint, and I rate old Toyota parts. Especially when were talking about 7.5 inch diff gears from a car that made barely over 120hp. Perhaps these had more meat on them and didnt require as much adjustment anyhow, I dont know. I used the lexus type 2 torsen from the 6 bolt rs200 rear end.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
