I have a greddy oil cooler and relocation kit worth near 1300 is this bad to
be run on my 20v?
my relocation one has two Oring seals already on it
be run on my 20v?
technically no as far as i know that Grex oil coolers have a inbuilt thermostat that keeps oil pressures and temps to a minimum before opening the thermostat allowing oil to flow around
for instance with cheap made in china ones with no thermostat you would not get the benefits that a inbuild thermostat has.
not all of them do...there are a few (3-4) different sandwich plates...only one of them has thermostat built in
MY AE86 BUILD
are you talking different brandss or different models of grex
different Greddy/GREX/Trust...whatever you wanna call them...
MY AE86 BUILD
So does anyone know where i can get the gasket between the block and the oil relo cause i took a gasket off the ryco z386 (4age oil filter) and its to wide it wont let the oil relocation thing screw on the block?
My relocation / cooler kit has no thermo.
Is it a big deal? (220hp, NA build)
