Hey all,
Not sure if this should be in here or one of the racing sections, but im after a little help from the guys a bit more experienced with setting up/racing track cars and a good understanding of gear ratios. My question is not whether or not I should buy it, because that's not what Im asking. Simply which one would suit my car better.
Im looking at a TRD Cross mission Gearset for my 86, and Im having a little trouble working out which one would be better for me. The car will always be NA, Im building a fairly aggro smallport or 20V in the next 6-12 months, And Im just trying to get the most out of it. When i purchase the gearset, the gearbox will also be rebuilt with all new bearings etc.
They come in 2 types, Type A and B. Type A Has even closer ratios, but Im not sure which one would suit my car better. (Hopefully the Type B as It's about $1K cheaper haha) The Type B gearset is around $1600 delivered as I type this with current exchange rate.
It's currently 4AGE Bigport hopefully making around 100kw's when tuned and about 130-odd with nitrous, using a TRD 3.9kg flywheel, Will shortly have TRD 4.56 gearset in T-Series rear end, and using 15 inch wheels with either 205/50 or 195/50 rubber.
Car is Used mainly for drifting. Basically trying to keep her right up in the powerband as much as I can. The CW+P will be going in first, plus the car will be tuned properly, with some more track time. Then the new gearset will follow.
Ive never been any good with gearbox ratios etc, and Im wondering which one would suit my car the best with the CW+P, tyre size, intended use etc. (You'd figure after years of playing Gran Turismo Id know exactly what im doing haha)
Stock Ratios -
1st 3.584:1
2nd 2.022:1
3rd 1.384:1
5th 0.861:1
TRD Type A Ratios -
1st Gear - 2.341
2nd Gear - 1.607
3rd Gear - 1.195
5th Gear - 0.886
TRD Type B Ratios -
1st Gear - 2.630
2nd Gear - 1.891
3rd Gear - 1.384
5th Gear - 0.861
Obviously, the type B is close ratio, and the Type A is even closer, but would it be too close with the 4.56 gears? As in 2nd gear would border on useless hard smashing the limiter? The Newara Imports 86 uses the type B set with a 4.56 CW+P, but also has a 200hp built 20V in it. Would driving style play a part as well? As in speed/line/aggressiveness?
And, Is it any stronger than a stock gearset? The OS Giken 1st to 3rd gearset was also stronger, but has now been discontinued.
And light that can be shed on this would be most helpful
