100mm at its lowest point is the legal height for a car. Check out some peoples build threads to get an idea of what height spring you need to run to get that height. Problem solved![]()
Can anyone tell me what the factory minimum ground clearance of an ae86 is so i can get an idea of how low i can go to stay street legal? Pretty sure my 27 year old suspension has sagged, so I can't get a clear idea from the car.
i think there is also some requirement that it must retain X % of the factory suspension travel.
if you are in QLD then you can check out that dodgy ass modification brochure.
also theres the 100mm that clinton has mentioned. but if you get a picky cop you might get done for the suspension travel one.
i belive the suspension travel defect has been used when cops want to get you for having stiff springs.
- Blaise Pascal
i got done for both at the same time lol, the cop actually told me the lack of travel was the main reason he made it a major defect
I'm in the NT. Basically if it can drive over a coke can, it's legal.
So does anyone know how low i can go? Are 2 inch lowered springs too much, or pretty well right?
id say that would depened on , wheel size, tyre size, camber settings, castor settings, spring stiffness, control arm length.
and even if you gave me all that info, i have no idea im sorry![]()
- Blaise Pascal
2inch is nothing, that wont get you pulled over...cutting 2 coils on the standard springs will cause some attention....
ive ran 220mm springs up front and 210mm on rears of my ae86...
cops has never mentioned that my car was to low...and i was using 13" and 14" rims...
bodykits with these spring hieghts WILL make it look lower as the kit hangs and will hit shit like a CAT or DOG or speedhumps etc...
dose
hahaha well im gona give it to you any way dave! lmao
xt130 arms
-2.5 camber
0 toe
castor increase jst a tiny bit from stock
185/60/14 on a 8 inch rim -12 offset
8kg spring
doubt ud be able to get rim and lip going wudnt be able to turn! lol
