Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 61 to 70 of 118
Thread: Lower Control Arm- Measurments & Compatibility
  1. #61
    Moderator Sam-Q's Avatar
    Endeavour Hills
    mounting points where? the mounting for the castor rod or the steering arm itself?
  2. #62
    Veteran bigm's Avatar
    Gold Coast
    caster rods and and swaybar sorry. slightly further back.
    Ae86 vs Mx73 v Ke55(same as xt130)
  3. #63
    Moderator
    Jay
    i have some xt130 lca's and p/s arms, should i get longer rack ends/tie rods or would the stock items have enough adjustment?
  4. #64
    Endeavour Hills
    the stock ones work well
  5. #65
    Hugh
    Johnny mentioned lock spacers before, but haven't heard anything since...
    If I put KE30/KE55 LCA's in my AE71, with an AJPS lock spacer on the rack, everything such as castor rods and sway bar and ball joint will bolt directly up, and I wont need to get different tie rod/rack ends...correct?
    If so, and then I put p/s arms on, would I then need to change tie rod/ rackend?
  6. #66
    Gold Coast
    Stock tie rod ends will work with or without power steering arms with the above setup
  7. #67
    Hugh
    and everything will directly bolt up?
  8. #68
    Gold Coast
    yes.
    power steering arms will only work with ae86 struts. not ae71....
  9. #69
    Hugh
    Interesting...I will be going 86 coilovers very soon so everything should fit well then...cheers
  10. #70
    Jul 2009
    Josh
    Ballarat
    i'm running te72 LCA's on xt130 struts in an st141......with about -1 camber
    the te72(t18) arms are the same length as ke70/st141 etc.....but,where the ball joint is they bend up on more of an angle?! hence creating negitive camber.....Or so I've found!
    Don't quote me on that!
    43ger
    Performance
    SINCE 2008
  1. Lower control arm identification
    By ke_70_blue in forum Technical - Questions
    Last Post: 13th November 2012, 06:41 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
