Results 21 to 23 of 23
Thread: *SOLVED* - Blacktop 20V High Idle
Threaded View
    Ok
    Seamus
    Milton
    Default *SOLVED* - Blacktop 20V High Idle
    Hey guys,
    I have a blacktop 20V in an AE86. It has a stock ECU. It's idling at about 2000rpm 'cold start', and 1500 at 'normal driving'.
    I have cleaned the ISC valve.
    When i remove the ISC valve from the engine and block off the 'idle tube' going up behind the head with my finger, the car idles perfectly at 800-900rpm. I have inspected every vacuum line, and i can't find any leaks.
    With the ISC valve removed, and that tube blocked off, shouldn't the car stall? Should the ITB's be sucking in air at idle? Could the vacuum "thingy" that sits under the ITB's be screwing with things?
    Love,
    Seamus
  1. 4age check connector, high idle
    By khoala in forum Technical - Questions
    Last Post: 9th April 2010, 12:27 PM
  2. High idle - the endless saga
    By Golberg in forum Technical - Questions
    Last Post: 4th May 2009, 08:19 PM
  3. high idle, please help
    By callum1 in forum Technical - Questions
    Last Post: 29th December 2008, 09:52 AM
  4. 4age HIGH idle
    By stylz in forum Technical - Questions
    Last Post: 27th July 2008, 08:39 PM
  5. help with high idle
    By DriftPlease in forum Technical - Questions
    Last Post: 14th January 2007, 06:11 PM
