XERO THEY ARE A VERY weird merge collector ,the 4 should all merge into 1 and have a cone or spear inside then taper then a taper cone back up to your disired dia
there was a teeny bit of room on robo's motor. probably not much more than a cm though heh
yea but how much was that XD
how does the slip joint work?
when it heats up does the inner pipe expand and then seal up?
offtopic. are you using a 20v sump cal? i thnk that gives abit more clearence+ other advantages. lazys got an adapter from tech arts?
yeah exactly right, they usually leak a bit when cold but once warm are completely sealed up
its a slip on collector with the insides tapering and spliced together. but i know what you talking about glen, my research has shown that with the collector being the desired diameter without the tapered peice makes no difference to power or flow.
depends highly on mods doesnt it? cams/intake/ect ect
you would probley want 421 also cal due to 7a lower revving? you probley know this i just wanna sound smartlol
but to make the power he is claiming (160rwkw) from a 2L 7age he'll need massive cams, which will need massive revs also...
i ended up with 4-1 rather than the 4-2-1 that i ordered due to a mixup from the supplier...but im thinking that im glad i ended up with them...
MY AE86 BUILD
