Page 4 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 ... LastLast
Results 31 to 40 of 174
Thread: Building a 7age.
    Veteran Robo86's Avatar
    Rob
    everyone knows mine but meh
    Final engine spec.
    7AGE
    -7AFE Bottom end - Honed, 0.5mm Oversize bores.
    -Standard crank (midsized)
    -Kings Main bearings
    -Standard Conrods (Resized + new bolts)
    -ACL Con-rod bearings
    -Hypatech Smallport 4AGE Pistons 0.5mm Oversized. (new)
    -Hastings Piston Rings
    -New standard thickness 4AGE toyota head gasket
    -Standard Bigport 4AGE Head, with some mild porting.
    -New Headbolts
    -4AC Flywheel
    -Apexi Intake
    -TRD copy extractors + 2.25 exhaust.
    -Compression ratio: 11.4:1
    105hp or something, chops my old BP
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Dec 2010
    Cal
    I pretty sure you won't get much more hp but the torque is great. But I think mat(pen15) car made close to 90kw on the 4age bottom end. And also when doing the said 1zz crank it tips it over a 2l.
    Rob
    yer mine pulls so much harder than 4age and cost me so little
    my corolla
    3274 5374 - Roy
    Nathan
    Lilydale
    im not sure mine belongs in this thread lol...
    -7AFE Block
    -7AFE rods
    -7AFE pistons
    -7AFE oil pump
    -7AFE Sump
    -4AC Head
    -Regrind Cam (270)
    -4AGEOil Cooler
    -WEBER 32/36
    Makes 60kw atw with more torque than any of my 4age's. would easy make more power with 4ac style pistons and more comp.
    Thats awesome!!! I rate it!!! Ive always thought if my 3tc shits itself in my ksev once i get around to it, id throw a 7ac together and see how that went lol
    Nathan
    Lilydale
    if you do end up doing it, remember that the key part to the 7ac is a Mitsubishi colt timing belt
    I have a question aswell, im just gathering parts for 7agte setup, using a blacktop head, i already have a brand new 7A oil pump, will this be sufficient compared to say, a blacktop oil pump?
    what differences are there, just volume?
    any help would be great
    Dec 2010
    Cal
    darrren
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    the thread is building a 7age but you get an A+ for effort i cant imagine why you would build a 7ac unless you had a magneto coil and mechanical injection but still a very cool engine what timing belt/chain did you use and things
    the dyno pull to 300rwkw
    Ok
    Seamus
    Milton
    Okay mine is kinda basic, not quite as crazy as delazy's monster. Should be fun though!
    block - 7afe stock
    crank - 7afe stock
    crank timing gear/sprocket - bazda modified (offset keyway)
    flywheel - J-Works 4kg chromoly flywheel
    bearings - kings
    conrods - J-Works H-Beam
    pistons - ae111 4age stock
    oil pump - 4age 16V + 4age 16V tensioner
    headgasket - stock ae111
    head - ae111 20v slightly ported
    cams - TODA-R 264, 9mm
    cam gears - ae111 4age stock
    timing belt - 4age 16v stock
    intake - ae111 itbs/70mm J-Wworks stacks
    extractors - RSR, soon to have J-Works 'Octopus' headers
    cooling system - Garage Annex
    ecu - ae111 4age stock, with Garage Annex modifications (unknown. could just be speed de-limiter)
    fueling- ae111 4age stock, TOM's or stock ae111 4age FPR depending on what the wideband says
    miscellaneous - ARP head studs and ARP bolts
    I hope to make 120-130rwhp. My <2" exhaust from headers to cat will be quite restrictive though.
    ^ Clicky clicky!
    Mathew
    Sutho Shire
    on my boss's 20v stroker 7a he uses a stock 20v timing gear on the crank and then uses a Peugeot timing belt how come you guys dont do the same?
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
