Car - N/A
Motor - 7AGE
Use - Paper weight
Problem - Rod small ends
occurs/started when - N/A
personal situation (if applicable)-
For those who have done a 7AGE conversion what have you done about the small end when using stock rods? I want to run 20V pistons since I will be using a 20V head. Do you just hone out the small end and run a floating gudgeon pin like in a 4AGE. If this is done wouldn't a hole be needed in the top of the rod to lubricate this pin like the 4AGE rods? Or have people just pressed the piston back into the rod and modified the 4AGE piston?
