These are surplus to my requirements so I am selling these off. They were recently pulled from an Echo from the Oxley ABC, which did get substantial inundation during the Brisbane floods a few weeks back. Although these were completely submerged in water, they were still installed in the car at the time, all the seals were intact and they are a fully sealed unit, so it is unlikely that they shouldn't work. I haven't personally tested these units, but I am confident that they should cause no issue. I am happy to offer a full (or partial if you wish to keep the working units) refund should they prove faulty. They come with all the plugs and at least 100mm of wire (up to ~300mm), which is more than enough to extend or wire in with some patience and a soldering iron.
I'm chasing around $150 plus postage for the set of four coils. Pickup is welcome for Brisbane based members.
--Coilpack Info--
(All measurements in mm)
** To ensure proper contact with spark plugs, try and allow for the depth from the coilpack mounting surface to the top of the spark plug contact within the given range. If not using the rubber seal, use the "Without rubber seal"
measurements.
More info on applications and wiring these coilpacks can be found .
