wow shes fucked, nice work marv, cant wait for updates!
When we dropped the oil a liter of water came out first.. Was awesome.
Getting exedy hd clutch tonight, flywheel machined, extractors. YYYEEAAHHH.
I'm thinking of doin some gussets from strut tower to firewall or should I use a tube? I would like to do it from the front of the tower to the rails too... Any suggestions?
Also should I seam weld or stitch weld? Stitch welding will flex where seam will crack? Not as stiff then?
CHS from strut towers to firewall won't really do anything dude. The firewall flexes way too much. If you wanted to do that, you'd be installing a full weld in cage. Keep it simple, dude.
Also, I think the question you want is, "Should I weld the seams with stitches or tacks".
I'll upload gusset pics when I can to show you some ideas. Gold 86 above has em. Should come around Sunday dude!
Example of gusset.
Totally going to do that! And brace from castor brackets. Mmm
So keen on purple engine bay!
Got a clutch! Hd exedy! Luke <3
So keen!!
they wouldnt do fuck all. look cool though.
id make some fender braces if your trying to brace up the front abit. they're pretty simple to make and are hidden
Pretty much what ke_70 said, dude. Gusseted plates aren't really gonna do anything other than add wank factor. If you go and build a proper strut brace and triangulate it back to the firewall, that'd be the best way to stiffen the front end and look cool in the process.
Wouldn't the gusset do the same thing? I see it heaps in ae86's
