Hen - Series 5 turbo boxes and the like do tend to quite sizeable...
As far as fitting a 13B goes, it depends on what model. Series IV engines onwards use side mounts which would probably be able to be modified to suit an AE86 crossmember, whereas the earlier 12As and 13Bs used mounts off the front of the oil pump cover. When fitting a Series IV or V engine to an old chassis like an RX2, 3 or 4 I used to just get my hands on an old 'front-mount' oil pump cover and whack it on, mating it to the old style crossmember. I can't remember if there was a specific cover to use, but 12A turbo rings a bell.
The SIV and V engines also used a mid-sump from memory, so likewise, I just used to use a sump off an RX4 13B or something. obviously the pickup will also need to be swapped to suit.
Low centre of gravity is one benefit of a rotary transplant, but if you are going to buy an engine budget a few grand for a rebuild as well.
Oh... btw - don't listen to all these other "cross-breeding" (lol!) comments. Variety is the spice of life, and a nicely tuned 13B will eat any 4AGE you're going to find on these shores.![]()
