forgot about under the seat, but i think mine may be a bit too big/long to go under the seat
hey guys, just want to check out (if any) amplifier instalations u guys have done on your cars as im sick of mine flying arround and pulling wires out
PS: if this is in the wrong section plz move![]()
i hope the question ur asking is how ppl have mounted the amps in the boot and not custom boot installs ppl have done.....otherwise this post will grow by about 20 times calling u a ricer fag
MY AE86 BUILD
if its not too big just bolt it to the back of the rear seats! im lucky because i have the battery in the boot my 5 channel nudges very nicely in between the box and plastic on the side
the seat has a curve in it and it has a lot of gaps and holes in it, and i doubt many pple here would do a custom boot install for their amp. Im not looking for a custom install tho, just a secure place to bolt it to.
i screwed a piece of mdf onto the back of the rear seat so its a flat surface then bolted my amp into the wood..
Insert witty comment here....
screw it to the back of the rear seat or if you have a sub screw it to the back of the sub
Use velcro loop tape on the bottom so it grips on the carpet and doesn'nt move around, a few bits should be plenty, it would make it easy to steal though, bolting to the back seats is a good way to do it, but then you need to mount the box somewhere.
mines screwd to the back of the back of the back seat
i unscrewed mine from underneath my passenger seat and stashed it in a pile in my garage.
wheelfriends.wordpress.com
