Page 11 of 13 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 101 to 110 of 127
Thread: Grant's b/t 7age
    Ok
    Seamus
    Milton
    4A engine mounts, alternator brackets etc all line up perfectly
    Gearbox bolts all line up perfectly, but you can't use the two lower supports, because there are no holes drilled for them on the 7A sump but you don't need them anyway..
    Also, the sump clears the crossmember by a cm or two too, and the extra height of the 7A still doesn't come close to touching the bonnet but you might not be able to use a cusco/etc strut brace if you are doing a 16V 7a, as it will foul on the plenum. A kelway brace fits though!
    I look forward to seeing power results from this thing!
    Jun 2009
    Nader
    Western
    The one I'm working on is for a clubman (Lotus 7 replica), so not too many clearance issues...
    How about clutch and flywheel issues??? 4A clutch with 7A flywheel?
    Cheers,
    Nader
    not looking forward to mounting my engine considering im using sptech mounts with cusco rubbers...should lower it quite abit ...hope it doesnt hit otherwise ill be dirty
    Because they don't need to mention it. all that stuff bolts up fine.
    about time arsehat...i was starting to think that my engine and car would be finished before the day this thing started...
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    wicekd shit!!!!
    now that you have done it, i have a shopping list.
    joe
    quit hatin get bakin!
    Veteran Robo86's Avatar
    Rob
    did this hit the dyno yet?
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Senior Member grantobius's Avatar
    grantobius
    nsw
    newy
    aus
    nar lol, its waiting on car trailer to be down. just need some funds and its hard when my daily needs rego grrrrrrrrrrrr
    Blacktop 7age reppin
    soooooo whats the go mofo?? last i heard it was close??
    Brad
    Central coast
    who is tuning it?
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. Grant's AE86
    By Granto in forum AE86 Owners Forums
    Last Post: 5th August 2007, 03:46 PM
  3. Grant's AE71
    By ae86hachiroku in forum KE70 / AE71 Owners Forums
    Last Post: 12th May 2006, 07:52 PM
