Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 41 to 50 of 127
Thread: Grant's b/t 7age
  1. #41
    Bangerang grantobius!
  2. #42
    from memory sam q workd it out to be around about the 11.5:1 mark...would have to find his post and see wat figure he used tho...
    but yeh, much respect to grant...
    ur VVT plug is on the way
  3. #43
    Senior Member grantobius's Avatar
    grantobius
    nsw
    newy
    aus
    Default thanx
    thanx for the comments guys, also thanx for sending that plug.
    My haltech rocked up 2day so this week will be wiring this week then tune next week then sexy time
    Blacktop 7age reppin
  4. #44
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    I'm as excited as you are.... well almost lol
    BENT MECHANIX - Garage 20:
  5. #45
    South Island
    Timaru
    New Zealand
    Internet rumour, possibly started by me.
    I had it all set up with a 16V belt and it did all line up exact,
    except the TDC mark where I lined the bottom cam gear up on the oil pump
    was not TDC as I had a mis-match of cam drive gear and pump.
    Did not find it until I had run the engine for quite some time,
    but I still run it like that, Turbo'd though, so for a non-turbo engine you'd
    probably need the cam timing set right.
    If you use a 20V head and a Blacktop 20V oil pump, a 16V belt fits with no mod's apart from cam timing.
  6. #46
    Jun 2009
    Grant
    California
    San Jose
    USA
    How close was it to correct timing do you think? I really want to retain VVT, there must be some way.
    Anyhow, I've replied to another thread in the technical section.
    To the OP, very excited to see what kind of number you put out.
    I was watching an old ae86 club where someone had built up a 5AG with 82mm pistons to get 1800cc....had something like 210 hp ...Orido was sliding it with ease. The inrease in torque was very noticeable and you could hear the extra torque. Awesome!
  7. #47
    fairly sure that ive seen that pass racing do an aftermarket VVT intake pulley not cheap tho....
  8. #48
    Grant Grant, not Grant #2. Can you just turn your engine to top dead centre and show Grant #2 pictures of the crank position and the cam gear positions.
  9. #49
    Jun 2009
    Grant
    California
    San Jose
    USA
    Please!
  10. #50
    South Island
    Timaru
    New Zealand
    [QUOTE=Grant #2;92208]How close was it to correct timing do you think? I really want to retain VVT, there must be some way.
    QUOTE]
    It was exactly 1/2 a tooth so 5 degree's cam rotation, 10 degree's crank rotation.
    It would be possible if you were accurate enough to re-drill the loactor holes in the cam wheels, probably the VVT one too.
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. Grant's AE86
    By Granto in forum AE86 Owners Forums
    Last Post: 5th August 2007, 03:46 PM
  3. Grant's AE71
    By ae86hachiroku in forum KE70 / AE71 Owners Forums
    Last Post: 12th May 2006, 07:52 PM
