Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: ae86 radiators
  1. #11
    Senior Member sdm86's Avatar
    May 2010
    Scott
    Tas
    Devonport
    s13 = ca18de ****
  2. #12
    ST162 radiator fits a treat.
    The driver's side bottom mount fits the stock sprinter mount (if you use the Celica rubber). The passenger side needs a bolted lower mount (from AE82 or ST162 or something similar) to be added. I managed to set it up so that I could still refit the original radiator if required too.
    Lower hose fits easy. Top hose needs some messing around.
    Works well with the stock ST162 thermos.
  3. #13
    Jason
    Broadbeach
    i don't have alot of room, was more interest in a 50mm core alloy radiator etc. that is direct replacement, same outlet locations, but seems not real popular
  4. #14
    <div class='quotetop'>QUOTE (drft86 @ Apr 15 2008, 04:29 PM) </div>twin core copper koyo....cheap and works wonders
  5. #15
    twin thermo excel ones work well from what sam was telling me, he made a how to install thread of it
  6. #16
    Coolangatta
    <div class='quotetop'>QUOTE (NFI @ Apr 14 2008, 10:03 PM) </div>This seems very similar to the camry radiator I'm running in mine. Search for a post by parrot. Easy to do assuming you can weld, or know someone who can. If you can't find an st185 (could be difficult), you can use mounts from an ae82 or st162, both bolted on the drivers side. I can't remember which, but one is narrower than the other, so a little bit of cutting before you weld it in and you won't even have to remove your original mounts.
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Camry radiator is off a SV21 isn't it? Pretty sure it's a similar model to that...
    I'm running a chunky-arse Koyo twin core alloy radiator... stock AE86 radiator height and length, but is like 56mm thick! I think it has more capacity than my intercooler!
  8. #18
    parrot
    If room is an issue and you are happy to do a bit of fabrication, the excel radiator is pretty neat from one I have seen in an AE86
  9. #19
    Senior Member Paw-DK's Avatar
    Mar 2010
    Paw
    Denmark
    General Area
    Christensen
    I'm using some celica radiator with a custo, fan thinks its bigger than the standard 86 radiators
    dunno which celica model it off though haha
  10. #20
    May 2006
    :blink: Just fitted my new radiator this arvo.......
    Details as follows:
    KOYO 53mm Polish alloy radiator Part #R0747. On e-bay.com, direct fit, 3x thicker than stock, about $460aus delivered.
    Without a doubt, one of the best alloy items I seen yet!
    :2thumbs: Steve
  1. AE86 Twin Core Radiators Ally and Copper
    By klusio in forum Car Parts For Sale
    Last Post: 23rd September 2009, 11:55 PM
  2. Ebay ae86 radiators
    By reecegze in forum General Topics (No Technical Questions)
    Last Post: 12th August 2008, 04:47 PM
  3. aftemarket radiators for ae86
    Last Post: 12th June 2008, 12:11 AM
  4. ae86 radiators
    By w84me in forum Technical - Questions
    Last Post: 23rd September 2007, 11:52 AM
