i want to buy a pair of 15x10 for the rear. the question is will they fit under the guards? and what tyres do u put on em? 185, 195 205??
195/50 does just fit, but they wont fit under stock rolled guards. I'm guessing they are -26 offset superlights?
<div class='quotetop'>QUOTE (KonaKid @ Oct 2 2008, 02:41 PM) </div>yeah there superlights..
theres no point running 10 inch wide rims if u r just going to run a 195 tyre....
if u want 195, use a 7 or 8 inch rim, as there will be less unsprung weight..
sorry if that came over as oppinionated but... why need for a 10, it doesnt make sense with 195
<div class='quotetop'>QUOTE (tony_kim @ Oct 2 2008, 02:47 PM) </div>
ditto....
the best part about wide wheels is the ability to put on monster rubber and get monster grip.....
10" is like 250mm, and you want to put on 195mm wide tyres??????
i guess its simliar to seeing cars with -5deg camber though.....
all about the looks :unsure: (i really laugh when i see 165 "stretched on a 6.5" rim)
as for the question yeah 10" is quite extreme for a 1000kg odd car, unless its a full on dedicated race car, and you can get UBER lightweight rims and some proper slicks, but as stated you'll need some of those N2 guards for that, or just take off your guards.....
- Blaise Pascal
Get them in a -12 if you do and you'll need 30mm bolt on flares or the guards flared the equivalent amount.
I'd run a 205/50 for safety reasons over a 195.
That said 10's are massive for a corolla and 9 is the biggest you'll ever need really.
as always, K0NAKID presents good advice.
dnt even bother with 10" wide rims on an ae86....looks like arse because u cant get it low enuff to look good....unless u have n2 guards....
MY AE86 BUILD
