Results 1 to 10 of 20
Thread: exciting news! tomei poncams for 20v
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Don't get me wrong,that is same duration I have in big port and has changed the motor.
    I'll definately be looking at a set of these for the blacktop in the new year.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Veteran slydar's Avatar
    Dimitri
    Default exciting news! tomei poncams for 20v
    Vol.207 11/10 4AGE 20 VALVE ENGINES PONCAM CAMSHAFTS
    just released. if the pricing of their 16v stuff in anything to go by this is great news.
    78's
    Jun released a 5ag crank also! Yiew!
    Glenn ke_70's Avatar
    Clay
    Barossa!
    is that the 81mm stroke one?
    Marco
    I did see a price of $600 for the pon cams. Conservative duration though, 264,256 9mm lift.
    Dimitri
    re conservative. well thats kinda the point of pon cams. theyre a drop in cam, just set the last and go. will work with stock ecu and stock cam timing, which is the main bonus, theyre optimized for the VVT already.
    still i can tell you from experience, 264/256 completely changes the nature of a 4age. i had this size in HKS cams in a big port/small port hybrid and it was a great engine.
    i just got emails back with those links from tomei. little more expensive than a 16v cam but there's a bit more work ion 20v cams so thats to be expected.
    78's
    Veteran slide86's Avatar
    Huw
    Hills
    Good turbo friendly cam spec.....
    Id be interested in a set of those 264 9mm cams.....
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I don't see the point when you can get 270/270 vvt proven cams in Australia that are known to work
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    More details on these 270/270 cams please sam.
    These tomei one look pretty sweet for the price they are asking.
  1. Tomei - The Engine Specialist
    By sundee in forum Spirited Drive
    Last Post: 27th June 2012, 02:07 PM
  2. Tomei 4AGE 16V Timing Belt
    By PeakingDuck in forum Car Parts For Sale
    Last Post: 22nd May 2012, 01:20 PM
  3. Tomei, BC Coilovers, CAS and more.
    Last Post: 5th December 2011, 09:45 AM
  4. Full race engine Toda, Tomei??
    By damo46 in forum Technical - Questions
    Last Post: 20th April 2008, 05:45 PM
