Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 39
Thread: Formula Atlantic
  1. #11
    Veteran johl's Avatar
    Johl
    here is the link but you will have to be a member to view. there is alot of good stuff on there so it is worth it.
    and i'l dump some pics here for people that cant be bothered to sign up
    $8500 200bhp with lower compression for daily driving. they said they can provide thinner headgasket and bigger cams to bring it back to 230bhp
    or the head by itself is $3500 and the block $4250 carb setup is $1400
    this engine cost $40000 to build and they are asking $15000
    4AGE 20V Race Head with TRD Throttle bodies & adapter plate $3,000.00
    Real Formula Atlantic Exhaust Manifold made to suit AE86 chassis. Cost $3,500.00 to order new. No longer made by Hasselgren. Brand new, never used. $2,500
    F.A. Ralt. cam cover $500
    Brand New HKS Turbo kit( new HKS ex. manifold, waste gate, blow off valve, down pipe, EVC controler,T04 turbo and Spearco intercooler ) $3800
  2. #12
    Senior Member kaibeecee's Avatar
    Pete
    13K US for that is a steal.
    the pectel ECU is 5-6k by itself. not to mention tuning it is in excess of $500 an hour........
  3. #13
    Johl
    yeh the bloke selling it said the harness and computer was 5k+ on its own
  4. #14
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Can someone explain why that motor in the crate has different length trumpets on it?
    Andy
  5. #15
    Timmy D
    North
    small trick tuners use, try and get abit of mid range and abit of top end instead of one or the other
    we tried it on the beams with 75 and 110.... dident work. would be interesting to try it with say 140 and 110???
    also some bikes come out with set ups like that OEM
    JJ
  6. #16
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I can supply 130mm trumpets for a blacktop, hahaha I better stop while you have enough money for food
  7. #17
    Senior Member HachiRoku's Avatar
    Oct 2011
    Owen
    Northern Beaches.
    Dammit those parts are so good & rare as
  8. #18
    Veteran Rice86's Avatar
    Richard
    Liverpool
    not sure if trolling...haha
    N2 AE86 don't use Formula Atlantic 4ages...
    N2 AE86 spec, the ones you see on youtube are still using normal 16v and 20v 4age, with just a lot of money spent on it.
    Most of the N2 AE86 you see in them youtube clips are carby, not EFI.. only the top sponsored cars like TRD are EFI as it still does cost money to do a dyno tune in Japan
    Just saying
    dose
  9. #19
    Ohhhh how I want that throttle setup!!!
  10. #20
    Johl
    saw your post on irl lazy.... will be awesome
  1. TE72 with Formula Atlantic Engine
    By richo in forum Toyotas in the Media
    Last Post: 8th July 2008, 07:40 PM
  2. Formula Atlantic on ebay
    By Huz in forum General Topics (No Technical Questions)
    Last Post: 22nd October 2007, 06:06 PM
