Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 21 to 30 of 70
Thread: the (ae86) weight reduction thread
  1. #21
    Mark
    Go on a diet!
  2. #22
    Veteran Rice86's Avatar
    Richard
    Liverpool
    ^^^ Thats not doing it right
    the awkward moment when doing it right the first time is not possible for the average hachiroku owner
    so the rule is simple: go full carbon, the hard part is going full carbon..so simple yet so hard
    dose
  4. #24
    Richard
    Liverpool
    on another note
    my coupe i bought was claimed to be at 970kg? without driver
    it had fiber glass vented bonnet and pair of front guards, no rear seats, 50% sound dening removed, not sure if it was 100% as not bothered to check under the front half of the carpet, no air con as per standard...had power steering setup and 90% of plastic interior, bucket seat for driver and normal for passenger..
    for a car claiming to be 970kg, it sure did felt lighter then when i drove a hatchback with very similar weight deduction without power steering on the hatchback too..maybe its just a coupe thing =p
    P.S Notch backs are more rigid then hatchbacks, can speak from experience now
    just sayin.
    dose
  5. #25
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I am very unsure about the carbon roof thing, I just don't think there's lots of weight in it and it's a strong structual component of the car
  6. #26
    Strangely I agree, but a lot of evo's run carbon roofs and drop reasonable weight..
    If I was to ever do it, it'd purely we wank factor..
  7. #27
    Endeavour Hills
    well I guess it is the single best place to loose the weight.
    Also anyone who has an electric sun-roof should take note- they are 20kg!!
  8. #28
    Veteran johl's Avatar
    Johl
    i would only go carbon roof if i had a reputable cage and it had gussets on the a and b pillars
  9. #29
    Veteran timbo's Avatar
    Tim?
    Wild West
    This is what I would do:
    Remove all trim
    Remove door cards
    Top of dash only
    Remove heater or air con stuff
    Remove sound deadener
    Remove glass and replace with lexan
    Remove bonnet and replace with fibreglass/carbon fibre
    Remove fuel tank and replace wheel well, add small fuel cell
    Remove radiator wall and replace with simpler, lighter design
  10. #30
    Evan
    Ballarat
    Here was my solution:
    Square and angle alloy. I found that only the two bolts on the inside of the headlight enclosures were needed to support the headlights and grill.
  1. weight reduction
    By bams_keto in forum Technical - Questions
    Last Post: 8th July 2008, 06:21 PM
  2. weight reduction
    By todd in forum Technical - Questions
    Last Post: 10th March 2006, 09:29 AM
  3. weight reduction
    By benno89 in forum Technical - Questions
    Last Post: 4th January 2006, 07:27 AM
