Results 1 to 10 of 13
Thread: ae86 offset rack spcers
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    Default ae86 offset rack spcers
    hey all dont no what section this should be but im sure you wont mind me posting it here
    ok i want a pair of offset rack spacers but dont even no if they excist for sprinter or i need to go get them made.
    ive desighned my own knuckles and i got decent lock using and a better feel threw the s13 front end but im going for more but i need the offset spacer to bring the rack ends more forward for no bind and then i can notch the control arm for more epic lock.
    any info would be appreciated thanks guys
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
    Troy
    Gisborn
    and i cant move the rack at all with the 13b in place will just hit the sump
    Moderator Sam-Q's Avatar
    Endeavour Hills
    A rotor sprinter sounds like fun.
    I don't understant what your asking though, you want to move it forward yet you can't because it will hit the sump?
    Veteran Skylar's Avatar
    Ken
    Don't do it. unless you wanna be replacing tie rods and racks on the reg.
    push your wheels back towards the firewall if you can, same shit without moving the rack.
    Endeavour Hills
    wtf!? how did you bend the rack?
    Troy
    Gisborn
    ok the part I want screws onto the rack and then ur rack ends screw into the spacer the spacer offsets ur rack ends forward closer to te control arm
    And I don't see how u bent ur rack man.. All the nissan boys run these spacers driftworks makes
    Them but not for sprinter
    I like to run big castor and I run flares and if I moves wheels
    Back
    It will look fail and handle
    Fail
    Endeavour Hills
    well that makes sense. I can make them but am too busy.
    A lot of people aren't running these spacers anymore and are modifying their crossmembers and moving the rack forwards because of exactly what Skylar has said and posted, namely, bending the rack shaft.
    Ken
    That's pic I posted is of an S13 rack and it was caused by running offset rack spacers. The guy initially tack welded the stuff on but it broke the welds and came loose and stripped the threads on the rack. He then welded them onto the rack. That pic is of broken rack number 4. That's just what happens when you run 9.5's on the front at like -10 offset. Guy eventually moved the rack forward 20mm.
    Another guy bent 3 tie rods in one event, 2 ikeya and 1 tein.
    Darren McNamara is making some rather soon to suit ae86...however as said, they seem to cause more dramas than they are worth...
  1. XT130's with P/S rack, longer rack ends?
    By Jimmee1990 in forum Technical - Questions
    Last Post: 6th December 2011, 07:31 PM
  2. **VIC** AE86 Struts, AE86 Brakes, AE86 cross Member, AE86 Rack
    By Mr Fujiwara in forum Car Parts For Sale
    Last Post: 4th August 2011, 07:46 PM
  3. [melb] rack ends and rack bushes
    By shakes in forum Car Parts For Sale
    Last Post: 10th May 2010, 09:28 PM
  4. Replies: 1
    Last Post: 3rd November 2009, 07:52 PM
  5. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
