Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 11 to 20 of 96
Thread: My 4agte tuff daily build yo!
  1. #11
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Update Oil Return..
    Just a quick update i welded in my oil return and straightened out the sump for a nice seal and put it back on. gonna use a 90degree speedflow fitting. It as a 5/8 bore so it should flow fine.
    Its been raining like crazy as we all know so today i improvised!!
    Oil return..
ID:	24871Click image for larger version.
ID:	24870Click image for larger version.
ID:	24872Click image for larger version.
    Can someone plz tell me how i can make my pictures bigger and so u dont have to click on the to see them??
  2. #12
    ACT
    Compton
    thats dedication for ya!lol
  3. #13
    Gone
    Joel
    Picton
    nice job are you sure that is coke in that maccas cup? sporting that umbrella may say something quite the opposite.... just a tip. be careful there is no weld splatter on that thread... because its alloy, you do it up, the weld splatter will chew out the thread and it will be F'd.
  4. #14
    May 2010
    Adam
    St George
    Thanks for the advice... The an fitting is steel (pirtek had both alloy and steel) I tig'ed it for a cleaner finish but yeah it looks like splatter but it's just grinding dust. Appreciate the help tho.. Cheers.
    As for the coke.. Well it was coke..until it rained!
  5. #15
    Gone
    Joel
    Picton
    haha, committed... nice work again man, look forward to some updates
  6. #16
    May 2010
    Adam
    St George
    Default Update...
    So hey havent updated in a while not much has happend been flat out with work and the rain is really not on my side. Got my turbo in and had a play around with how im going to run the air filter and cooler piping. Ordered a new head gasket from toyota so that will be on the to do list for the weekend, also have my alternator setup coming this week and also a s13 alloy radiator, so hopefully i will have all the motor stuff mostly sorted out.
    anyway pics explain better...
    BTW..can someone plz tell me how to make my pictures bigger..
  7. #17
    Senior Member killabeez_1985's Avatar
    Apr 2010
    Adam
    Mount Gravatt
    man ive never been keen enough to work on my car in the rain and or build a tarp cover so that i could work in the rain. Admire that dedication!
  8. #18
    Bryan
    Waterford
    Tramore
    Ireland
    Looks good. I will be interested to see how the GZE ecu copes as I'm doing the same.
    Also that's an oversize crank pulley for increasing boost on a GZE so you could sell it on.
  9. #19
    May 2010
    Adam
    St George
    Yeah see how the CPU goes I've been told it should be ok up till 10psi ish. The crank pully how much are they worth should I just run it or get a standard one?
  10. #20
    Member ShowUsYourTints's Avatar
    Jan 2012
    Shannon
    Sydney, Northern Beaches.
    Hey mate,
    Build looks awesome. Quick question though, what Clutch Master Cylinder did you use?
    Cheers,
    Shazza
  1. 4AGTE Keto Build.
    By milto in forum KE70 / AE71 Owners Forums
    Last Post: 6th August 2012, 12:26 PM
  2. The daily build
    Last Post: 10th January 2010, 06:04 PM
  3. My New 4AGTE Daily
    By 44GTE in forum AE86 Owners Forums
    Last Post: 9th January 2009, 02:16 PM
  4. 4AGTE Build Specs
    By orangechargd86 in forum Technical - Articles
    Last Post: 27th March 2008, 11:10 PM
  5. KE70 Daily build up
    By -Leigh- in forum KE70 / AE71 Owners Forums
    Last Post: 10th September 2006, 10:57 PM
